RomanV wrote:Since SUVs are to aerodynamics what irishmen are to sobriety, I think the windows down/up wouldnt make much of a difference to their already crappy coefficient of drag.
However if you were in a sports car with a low C.O.D., having the aircon on could possibly be more efficient than having the windows down at highish cruising speeds.
Then again, if you were so concerned about fuel economy, you wouldnt drive a gas guzzling SUV anyway, would you?
luvnit wrote:RomanV wrote:Since SUVs are to aerodynamics what irishmen are to sobriety, I think the windows down/up wouldnt make much of a difference to their already crappy coefficient of drag.
or a high performance car
CozmoNz wrote:luvnit wrote:RomanV wrote:Since SUVs are to aerodynamics what irishmen are to sobriety, I think the windows down/up wouldnt make much of a difference to their already crappy coefficient of drag.
*ponders if a prius hybrid engine/s setup will fit in an aw11...*
MrBeef wrote:yes that is the new chrysler
RomanV wrote:Fuel economy is just as much to do with the cars weight as anything....
eg. a big heavy car with a small engine, you're going to have to work it hard just to get anywhere.
Or a v8 in a tiny car, will only take a tiny blat on the throttle to get it up to speed.
