Problem is though, it wont keep running
Anyone have any ideas?? Thanks in advance
All lines havnt been touched but have rechecked and all looks goodEVL20V wrote:vacuum leak somewhere?
Fuel pressure seems to be fine, has the 20v pump running and yeamatt dunn wrote:lack of fuel pressure.
Will do that, its all plugged in, maybe some wires need to be connected somewhere.... Hope your back soonMr Revhead wrote:checked ya AFM plug?
and theres another common thing that escapes me now....
ill be back.......
Yea that would be awesome, im home again on sunday avo, stupid broken ankle makes getting around toughdeaf_rattle wrote:i would be keen to have a look at your wiring sometime.
would that be sweet?
where is that??13 wrote:check if ur idle speed control valve has been pluged in power....
where through the 20v loom does it run?Simon85MR220v wrote:There's an earth wire on the AFM plug that needs to be connected to....... an earth!! White with a black trace. Had the same problem with the transplant into the AW.
Ok have done that just now and didnt make a diffKinLoud wrote:Put a jumper wire from the FP to the B+ in the diagnostic plug.
This bypasses the fuel pump relay. If you engine runs normally then you will have to sort out a wire from the AFM switch to the fuel pump relay.
Yea dont think its that after testing itsergei wrote:as pple said, fuel pump relay not connected thru AFM, had to sort it out when I did wiring for a 20v conversion on a 4AFE....
XS1V wrote:Ok so ive traced it pretty much top the AFM i think.... it will run if you hold the flap open a little with your hand, so what could that be?
deaf_rattle wrote:hey
You going to be home this weekend?
if so would it be sweet to pop round?
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
