Zak wrote:Dunno if it makes a difference on a T50 box, but in GTX box's putting better bearings in them makes them quite a bit stronger.
Because of the angle cut gears, the input and output shaft push each other apart and then s**t just hits the fan and all hell breaks loose in there
turbo86 wrote:better bearings dont make the gearboxes stronger it just makes it last slightly longer then the usually standard bearings, if you want to make your gear box stronger you get all the gears cryogenicly frozen and get steel selectors shifters made up. ( toyota w series box )
Mr Revhead wrote:hehe the dunns can kill anything![]()
cept kp60 starships![]()
nothing is bulletproof, EVERYTHING has its limits
