Nut on crank shaft pully...
Postby Quint » Wed Dec 21, 2005 9:03 pm
Went to do my cambelt today (was doing a full service to my car before i moved down south, have no tools downt there yet) Anyway, couldn't get the bolt off that was on the crankshaft pully, used a 800nm rattle gun, didn't even touch it, also bent a 20mm Iron bar useing it as a lever and i was makeing the clutch slip (had it in 5th with handbrake and foot brake hard on) No idea how to get it off, does anyone have any hints or ideas? The manual says, 'put on SST and turn' Not much help :/
Oh its a GA-70 with the 1G.
If all else fails, is it a non-interferance head? (does the piston hit the valves?)
Quint
Postby Elmo » Wed Dec 21, 2005 9:18 pm
One crude way that does work sometimes is, jam a bar in there (with socket on nut) and turn the key!!
Obviously make sure the bar is jammed so as to not turn anymore with engine turning clockwise.
Oh, and obviously this ISNT a recomended way of doing it as severe damage, harm and death can occur, so if you do try this, be wared, you have been told!
Elmo
Postby Malcolm » Wed Dec 21, 2005 9:20 pm
that's how I do it, works every time :)
Postby deaf_rattle » Wed Dec 21, 2005 9:31 pm
take a spark plug out and rotate the motor by hand till the spark plug is as far down as it will go, then stuff some soft nylon rope in there (not forgetting to keep hold of an end), then rotate the motor to tdc and then try and get the bolt off with a power bar.
works everytime and aint dodgy
Postby slighty_sykotic » Wed Dec 21, 2005 9:41 pm
Elmo wrote:One crude way that does work sometimes is, jam a bar in there (with socket on nut) and turn the key!!
Lol, my mechanic mate was taught that method at his course...
And yeah, worked on my 20v.
--Sykotic
slighty_sykotic
Postby YeMs » Wed Dec 21, 2005 9:53 pm
bigger rattle gun :D but yeh iv seen the 'jam the bar and turn the key' trick go wrong and its not pretty. say buhbye to radiator and oil cooler etc.
Your local Hybrid Elite tech
YeMs
Postby Lloyd » Wed Dec 21, 2005 10:04 pm
Dont jam the bar, leave a couple of cm of gap. Its supposed to work the same way as a rattle gun, sudden impact. Jamming it tight wont be nearly as effective
Re: Nut on crank shaft pully...
Postby Spannergal » Wed Dec 21, 2005 10:37 pm
Quint wrote:The manual says, 'put on SST and turn' Not much help :/
wtf? i'm doing work experience at a toyota dealership and I've never seen a SST used for removing the crank pulley for the cambelt.
Spannergal
Postby sergei » Wed Dec 21, 2005 11:31 pm
if nothing else works, drill it out (start with 5mm then work your way to 10mm drill bit in 1mm steps)...
Postby ATAl » Wed Dec 21, 2005 11:57 pm
I've always just jammed a big screwdriver in the flywheel ring gear - then the crank and pulley cannot move at all and it's easy to get off.
ATAl
Postby Si » Thu Dec 22, 2005 8:14 pm
The official SST wont be as rangi as that, purpose is to be able to hold the pully whilst removing/reinstalling the bolt.
Current: , '96 SubaruImpreza
Si
Postby rollas22 » Fri Dec 23, 2005 8:57 am
The starter motor trick worked for me in my levin and bmw!
KE-Corolla's for life!!!
rollas22
Postby dohca » Fri Dec 23, 2005 4:35 pm
SST = Special Service Tool..
dannyp
dohca
Postby SCK » Tue Dec 27, 2005 10:01 pm
Or you could call ones of those truck tyre repair trucks. I did that and it cost me $20 for the guy to come to my home. Took him about 30 secs to get a crank bolt undone.
>>>>>>>>>> SCK <<<<<<<<<<
SCK
Postby solidog » Mon Jan 02, 2006 2:14 am
--Sykotic
Yeah mate, its how it goes in the trade! im halfway thru training to be an auto sparky and for stubborn crank pulley bolts we use a strongarm and near enought to the floor and quick flick of the ign!
NOTE: dont put you head, or your boofhead friends head in engine bay (to see whjat happens) thats just asking for a socket in the face!
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
