T3/4 spool time?
Postby Stu- » Mon Dec 26, 2005 9:03 pm
Possibly an intercooler problem as the top of my intake is dead cold after a good thrash, although it is a bigger turbo.
Project Thread
Stu-
Postby Bazda » Mon Dec 26, 2005 9:07 pm
maybe you shoudl just drive with no bonnet or put some tin foil around it :P
Postby JamesM » Tue Dec 27, 2005 10:07 am
heat soak from head?
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Andy from the block » Tue Dec 27, 2005 7:35 pm
Stu- wrote:Possibly an intercooler problem as the top of my intake is dead cold after a good thrash, although it is a bigger turbo.
I dont see how it could be a intercooler problem, since the piping
jst after the cooler is cold, yet the piping going into the intake manifold
and the manifold itself is hot. I think it is a radiant heat or hot air exposure
problem thats leading to heat soak of not only the piping but of the
whole area in the engine bay.
Bazda wrote:maybe you shoudl just drive with no bonnet or put some tin foil around it :P
Nah il just wrap my whole car in tin foil and squeeze a bit of lemon over
it and let it simmer till medium rare. 8)
Andy from the block
Postby Bazda » Tue Dec 27, 2005 8:00 pm
its just heat soak from the engine bay, nothing to worry about andy, your engine bay cant be cold like the intercooler.
Postby Drifter4ag » Tue Dec 27, 2005 8:42 pm
try touching a normally aspirated intake manifold once its been running for a bit or light thrash .. you will find the temp to be not much different.
you can use the exhaust wrap on the intake manifold side of the piping if you are real worried.
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby barryogen » Wed Dec 28, 2005 8:06 am
Drifter4ag wrote:try touching a normally aspirated intake manifold once its been running for a bit or light thrash .. you will find the temp to be not much different.
mine(NA 2zz) is stone cold unless I really rape it, then it gets to "can't touch it" temps.
Drifter4ag wrote:you can use the exhaust wrap on the intake manifold side of the piping if you are real worried.
Have seen it done, it looks bad, but seemed to do the job.
Infact, the weirdest one I've seen had all piping from turbo to IC, IC to plenum all heat wrapped, looked ghetto as.
They assured me it helped, I guess it would cut down on heat soak.
barryogen
2ZZ Guru in training
Postby Drifter4ag » Wed Dec 28, 2005 8:21 am
ive done it to my car and it works a treat ..but as you say ..just looks bad .. i make up for it by being totally handsome and uber cool .. i dont even need to put "for sale" on my back window ..hoes just jump in the passenger seat.
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Ako » Wed Dec 28, 2005 9:40 am
How is that ghetto - its called "functional" :D
I did it on my last VR4 - dropped intake temps noticably around 15 degrees, actually gave an improvement you could feel. Plus I rate go faster type stuff in the engine bay above having chrome pipework 8)
Ako
Postby Andy from the block » Wed Dec 28, 2005 6:37 pm
I was thinking of cutting up a windshield sun shield (you know, those
large reflective ones) and wraping that around my IC pipe in order to
save money. If those sun shields are designed to reflect radiant heat
away from your car's interior, why cant it work for your IC piping?
My plan was to wrap the pipe with paper towels first
(since paper is a insulator) then wrap with sun shield, thus providing
a multi layer surrounding. Hows that for ghetto? :P
Andy from the block
Postby vvega » Wed Dec 28, 2005 6:55 pm
Andy from the block wrote:I was thinking of cutting up a windshield sun shield (you know, those
how bout
you rapp it with pink bats then use alloy tape to hold it all togethier taping in a continous sprial
thats wat we used to do with planes and it looks damm cool
with a little thought not everthing pratical needs to look getto
kinda looks liek this
arh well
v
vvega
Postby JamesM » Thu Dec 29, 2005 8:36 am
that looks like rather large chilled water piping
that says acoutical insulation tho...
maybe its steam pipe.
Team Megasquirt
1984 AE86
JamesM
Postby vvega » Thu Dec 29, 2005 10:14 am
nah that was a example of what it ends up looking like
that piccy is from NASA :Dbut yea :) i guess you get the idea :D
v
vvega
Postby JamesM » Thu Dec 29, 2005 10:32 am
yea haha i realised the pipes arnt that big in your engine bay.....
thats my job to deal with that sort of piping.. thats a nice big solenoid there also.
you can actually buy pipe insulation called armoflex with shiny tin clading.. quite cheap also.
Team Megasquirt
1984 AE86
JamesM
Postby Andy from the block » Thu Dec 29, 2005 12:19 pm
ae-86_lad wrote:you can actually buy pipe insulation called armoflex with shiny tin clading.. quite cheap also.
Would it be cheaper than cutting up a sun shield? :P
Where can you get it?
Andy from the block
Postby JamesM » Thu Dec 29, 2005 1:47 pm
forman insulation i think is the name of one of the places that has it..
price : i just priced a small job and we allowed 360$ for about 10m of piping.. (price included labour).. i cant seem to find the rates.. so yea..
probably similiar pricing to heat wrap.. (but would do better job probably)
Team Megasquirt
1984 AE86
JamesM
Postby barryogen » Fri Dec 30, 2005 8:21 am
Ako wrote:
barryogen wrote:looked ghetto as.
I was only commenting on how it looked... it looked ghetto. :)
barryogen
Postby Andy from the block » Fri Dec 30, 2005 12:56 pm
ae-86_lad wrote:price : i just priced a small job and we allowed 360$ for about 10m of piping.. (price included labour).. i cant seem to find the rates.. so yea..
Oh ok.
I think il probably give my sun shield idea a go since I have some sun shields around somewhere.
I'l let u guys know how it works out :P
Andy from the block
Postby 1598cc » Fri Jan 13, 2006 11:24 am
yeh i had full boost, 18-20psi on a ht18s rb20det exhaust housing by 4000 on 0 degrees timiing.
1598cc
