Stu- wrote:Possibly an intercooler problem as the top of my intake is dead cold after a good thrash, although it is a bigger turbo.
Bazda wrote:maybe you shoudl just drive with no bonnet or put some tin foil around it
Drifter4ag wrote:try touching a normally aspirated intake manifold once its been running for a bit or light thrash .. you will find the temp to be not much different.
Drifter4ag wrote:you can use the exhaust wrap on the intake manifold side of the piping if you are real worried.
barryogen wrote:Drifter4ag wrote:try touching a normally aspirated intake manifold once its been running for a bit or light thrash .. you will find the temp to be not much different.
mine(NA 2zz) is stone cold unless I really rape it, then it gets to "can't touch it" temps.Drifter4ag wrote:you can use the exhaust wrap on the intake manifold side of the piping if you are real worried.
Have seen it done, it looks bad, but seemed to do the job.
Infact, the weirdest one I've seen had all piping from turbo to IC, IC to plenum all heat wrapped, looked ghetto as.
They assured me it helped, I guess it would cut down on heat soak.
Andy from the block wrote:I was thinking of cutting up a windshield sun shield (you know, those
large reflective ones) and wraping that around my IC pipe in order to
save money. If those sun shields are designed to reflect radiant heat
away from your car's interior, why cant it work for your IC piping?
My plan was to wrap the pipe with paper towels first
(since paper is a insulator) then wrap with sun shield, thus providing
a multi layer surrounding. Hows that for ghetto?
ae-86_lad wrote:you can actually buy pipe insulation called armoflex with shiny tin clading.. quite cheap also.
Ako wrote:barryogen wrote:looked ghetto as.
How is that ghetto - its called "functional"![]()
ae-86_lad wrote:price : i just priced a small job and we allowed 360$ for about 10m of piping.. (price included labour).. i cant seem to find the rates.. so yea..
probably similiar pricing to heat wrap.. (but would do better job probably)
Users browsing this forum: Majestic-12 [Bot] and 14 guests
