TRD001 wrote:So I would have to change the compression, pistons, conrods, get an aftermarket computer,exhaust manifold, Is there anything Im forgetting here?
what's your current exhaust set-up?
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
whats your current exhaust set-up?TRD001 wrote:So I would have to change the compression, pistons, conrods, get an aftermarket computer,exhaust manifold, Is there anything Im forgetting here?
TRD001 wrote:I have no exhaust at the moment,
AJz wrote:^^^ i think you've covered everything there........![]()
RevHead made some good gains, however I wouldnt call them substancial
You state you don't want to alter the cams. However this is where you will get the best gains, and mainly through loosing your lower to mid range.
Mr Revhead wrote:RevHead made some good gains, however I wouldnt call them substancial
i would! about 10% increase in peak torque and power, and a far better torque curve. amazing results from just a plug in ecu.
i wouldve have believed it myself unless i saw it and did it back to back.
made a huge difference on the road too, heaps more torque exactly where the silvertop needs it![]()
however i thinki was lucky, the SARD ecus appear to be programmed to certain engines, i was lucky to get one that worked with mine. others may not be as good on a stock engine
