Fuel/Ignition Problems.....
Postby Dell'Orto » Fri Dec 30, 2005 9:11 pm
MINTFX wrote:Ohhh sh!t, Maybe i should leave it till tomorow I am really tired. I cant find the little black box either? Any pointers as to where itll be. (Already had a good hunt around the battery area.
Ought to be there
Postby MINTFX » Fri Dec 30, 2005 9:25 pm
Nope?
MINTFX
Postby Alex B » Fri Dec 30, 2005 9:41 pm
Some older efi toyotas just had a whole lotta random plugs no pluged into anything around that area, you link the 2 wires in one of those plugs dont ask me which one tho...
Postby RedMist » Fri Dec 30, 2005 9:54 pm
pyro_sniper2002 wrote:Get the fuel pressure checked out.
Seconded.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby MINTFX » Fri Dec 30, 2005 10:30 pm
Yea, Dont want to go hooking the wrong ones up :lol: I thought about rolling it off a cliff and claiming insurance :wink: Then I thought about all the hard work me and my dad put into the bodywork. Just to clear up it us an 85 Bluetop 4AGE FXGT.
MINTFX
Postby Caveman » Sat Dec 31, 2005 11:11 am
NZ new? I wonder if they have the diagnosis boxes. I cant remember one on my mates FX NZ new.
Caveman
Postby MINTFX » Sat Dec 31, 2005 11:38 am
Na not NZ new. Was imported.
MINTFX
Postby ChaosAD » Sat Dec 31, 2005 11:59 am
In the early model FXGT's (ie your one) there is no black box. Instead there is a bundle of yellow plugs.
In the enginebay on the passenger side of the firewall, near the fuel filter. look for a yellow two pin plug with a rubber cap over the end of it.
That is the check connector which you bridge to check fault codes and timing.
ChaosAD
Postby Ako » Sat Dec 31, 2005 12:02 pm
You have spark.
You have no ignition.
You haven't checked for fuel yet - even if its munted and running crazy, it will at least fire if it has spark and fuel.
Very easy to see if you have it...
Ako
Postby MINTFX » Sat Dec 31, 2005 12:05 pm
Im going to grab a voltmeter of my mate today so I will check if the fuel pump is getting any power to it. If it is then how can I tell if it is pumping or not?
MINTFX
Postby Caveman » Sat Dec 31, 2005 2:10 pm
Best way is to undo a fuel line and crank it for a second or so. Should get about a cup of fuel come out 8)
I've had a fuel pump do crazy things. Getting full power, running fine for 10 seconds then spluttering and going crazy.
Best way to check is actually see the fuel flowing.
Caveman
Postby MINTFX » Sat Dec 31, 2005 10:41 pm
Sweet ill give it a try tomorrow and see how it goes. If im up to it :lol:
MINTFX
Postby MINTFX » Sun Jan 01, 2006 1:25 pm
Well, I went out to my car today to give it one final crank over and it started 8O Warmed up fine (Gave me a chance to fiddle with my new front door pods). So the fuel pump WAS pumping fine... Turned it off, then tried to crank it back over and it would fire but die. Popped the hood and found those three yellow plugs. One big with 4 slots inside, one medium with 2 slots and one small with one slot. Which one is the diagnostics one? Thanks for your help so far!
MINTFX
Postby CozmoNz » Sun Jan 01, 2006 1:27 pm
Maybe take a picture of your engine bay and we can point out the plug or where it should be?
Rayne For President!
CozmoNz
Postby MINTFX » Sun Jan 01, 2006 1:55 pm
Theres one quick pic I took with my phone, Too the far right of the strut brace just bellow that black cable tie is where the 3 plugs are located. One large one with 4 holes, one medium one with 2 holes and one small with one hole in it.
MINTFX
Postby Mr Revhead » Sun Jan 01, 2006 3:58 pm
CHAOSAD wrote:In the enginebay on the passenger side of the firewall, near the fuel filter. look for a yellow two pin plug with a rubber cap over the end of it.
hmmmmm i wonder which one :P
Postby MINTFX » Sun Jan 01, 2006 6:57 pm
Well it is the day after New Years Night :lol: Sweet I will go off now, bridge that and turn the key on and see if there are any codes coming up.
MINTFX
Postby MINTFX » Sun Jan 01, 2006 7:14 pm
Okie Dokie. It just flashes intermitantly. Like 1.......1.........1........1.......1.......1. About 3-4secs between each. Im guessing this might mean 11? EDIT, Or does that mean nothing is wrong that it can find?
MINTFX
Postby MINTFX » Sun Jan 01, 2006 8:40 pm
Talking to myself again :D Pretty sure its the fuel pump now. Tested the power going to it and its getting 12v when im cranking it over. When I stop trying to crank it over the pump is making a funny 'donk donk donk' sound, Which doesnt sound very good. Perfect timing after I had JUST filled the whole tank :( Now wtf am I going to do with 45litres of petrol?? And how am I going to syphon it out, theres no blimin drain hole in the petrol tank!
MINTFX
Postby Caveman » Mon Jan 02, 2006 1:01 am
syphon it ghetto stylez, suck on a hose and chuck it in your mums car, get her to repay you later.
Your lucky if its a fuel pump, easy fix. Just undo the lines, drop the two belts holding it up, drop it down, replace pump, put it back and your done. You could probably do it with the fuel in it. Apparently your suppose to replace the o ring sealing the fuel pump and tank...
Toyota pumps are pretty generic. I replaced a st162 pump with a '92 bluebird sss pump. Same mounts, depth, etc.
Caveman
