Both have the tagra tops and come in that bright red.. colour
So what would you take? (both manual and stock)
The mr2 2 litre turbo (240HP, 1250kg) or the big 300zx v6 TT (300hp, 1550kg)
Their performance is very similar mr2 has a wieght KG to Power Kw ratio of around 6.9kg/per kw,
the 300zx is around 6.9kg/per kw so they are matched for power on the ground!
Only difference is ones mid engined and the others front. Plus the z is like a boat.. to some people
