Mr Revhead wrote:why do you want to drain the tank?
1998 wrote:syphon it ghetto stylez, suck on a hose and chuck it in your mums car, get her to repay you later.
Your lucky if its a fuel pump, easy fix. Just undo the lines, drop the two belts holding it up, drop it down, replace pump, put it back and your done. You could probably do it with the fuel in it. Apparently your suppose to replace the o ring sealing the fuel pump and tank...
Toyota pumps are pretty generic. I replaced a st162 pump with a '92 bluebird sss pump. Same mounts, depth, etc.
Mr Revhead wrote:you have checked to make sure theres no acsess panel under the seats havnt you?
MINTFX wrote:Took the fuel line off the top of the fuel filter to see if there was anything being pumped. A fair bit came out when I gave it a quick crank over so either its faulty or theres not enough pressure as the injectors need 50-60psi to work? New fuel pump from Ripco is about $280 inc gst trade which is friken rediculous. Going to have to organise and auto elec or something to pop up, I dont want to go through the hassle of taking out the petrol and replacing the pump to find its not that.
Users browsing this forum: Bing [Bot] and 12 guests
