20v power steering belt part number?
Postby deaf_rattle » Fri Jan 06, 2006 3:02 pm
can anyone tell me the part number of the belt i need for the power steering for the silvertop 20v.
not running the a/c compressor, just crank tensioner and p/s pump
Postby sergei » Fri Jan 06, 2006 3:11 pm
I think 20valves never came out without AC... You could try NZ NEW Corolla GTI belt, they did come out without AC, as well as the tensioner bit (as it has got grooves)...
Postby deaf_rattle » Fri Jan 06, 2006 3:19 pm
hmm
i might have to measure it up and get a generic belt for it then.
Postby neo » Sat Jan 07, 2006 11:17 pm
I have just removed the a/c and made an adjustor (bolts to the right hand side top two bolts on the pump itself) so I could use the factory 101 bracket, i used a 5pk890 belt.
neo
Re: 20v power steering belt part number?
Postby RedMist » Sat Jan 07, 2006 11:53 pm
deaf_rattle wrote:can anyone tell me the part number of the belt i need for the power steering for the silvertop 20v.
Your crank tensioner won't work in that configuration. It works on compression not tension as such wont work without the AC pulley there. You'll need to either make up a new tensioner or modify the PS pump mount to make it lever outwards to tension the belt.
The size of the belt will depend on how you end up developing your tensioner.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby sergei » Sun Jan 08, 2006 12:24 am
or you can bolt on a tensioner form AE82 NZ NEW wich is designed to work without AC...
Postby EVL20V » Sun Jan 08, 2006 2:23 am
5PK840, contact pioneer auto parts (auckland?) :wink:
EVL20V
Postby RedMist » Sun Jan 08, 2006 7:20 am
sergei wrote:or you can bolt on a tensioner form AE82 NZ NEW wich is designed to work without AC...
Now why didn't you tell me that two years ago.... mind you I still would have gone with modifying the PS pump bracket.... belt runs around pulleys for longer and its slightly lighter.... every gram counts... Thats why I'm a lean 100kg machine.
RedMist
Postby quinny » Wed Jan 11, 2006 12:02 am
dont know what belt size but on my blacktop to ditch the aircon unit just put a nut on the ajusting bolt on the other side of the bracket from the bolt head and it will reverse the factory tensioners pressure direction, this idea came after almost a year of living with that bloody thing. i hate them
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby deaf_rattle » Wed Jan 11, 2006 6:26 am
hey, cheers for the idea, will have to have a look at that.
Postby RedMist » Wed Jan 11, 2006 6:34 am
Might just be me, but I managed to bend the tensioner bolt using it in the above described fashon.
I'd go with Sergei's idea or modify the PS pump mount.
RedMist
Postby deaf_rattle » Wed Jan 11, 2006 6:36 am
RedMist wrote:Might just be me, but I managed to bend the tensioner bolt using it in the above described fashon.
your car might just be too hard out for that.
will the ps system be alright if i dont run the belt to start off with?
till i sort something out?
Users browsing this forum: Bing [Bot] and 27 guests
