GT-Z or GT-ZApex
GT-Z or GT-ZApex
Postby Tru3no20v » Thu Jan 12, 2006 8:30 pm
Hey
atm i have a AE-101 Trueno GT-Apex, going stong no probs.
Im keen for a gtz also but have been told that i could bolt on an SE12 or SE14 to my stock standard 20v.
Just wonderd if any one has done this befor, or if anyone thinks id be better of just getting a stock GT-Z and working that eg Turbo.
Any views welcome a, jst doing this as like research befor i make plans
Also, yeah wrong section but, if anyone knows of any GT-Z's for sale id be kenn to know, not alot on trademe,
ae82 fxgt corolla
<<<-------- . . . the names old
Tru3no20v
Postby Dell'Orto » Thu Jan 12, 2006 9:22 pm
You could just bolt the SC12 or 14 onto your motor, but it wont last long :P.
Really comes down to how handy you are mechanically, a 4AGZE swap would be the least hassle.
Postby Lanius » Fri Jan 13, 2006 8:44 am
Unless you're *definitely* going to mod the GT-Z, you might as well hold onto your Apex. The power difference isn't that significant between the two, the GT-Z just feels faster because of the buckets of torque it has from idle. They tend to run out of puff above 5500rpm, and a decent silvertop only begins to shine above 5500rpm.
Of course if you've got $5k saved up and you're going to turbo the beast, then definitely get the GT-Z :)
Lanius
Postby Leon » Fri Jan 13, 2006 9:16 am
By far the cheapest solution is to sell the n/a and buy a GTZ.
Postby Mr Revhead » Fri Jan 13, 2006 10:37 am
converting an APEX to a GTZ is a pita unless you have the comple donor car next to you. far cheaper and easier to just buy a GTZ.
you can run a s/c on the stock 20v. you will however need a good intercooler and ecu. for a longer lasting engine though you really want to put 4agze pistons in it.
so the 2 best options i can see is:
turbo or s/c your currant car. both requiering rebuild and ecus etc to do it right
sell the 20v and buy a GTZ. then mod that.
both wil prob work out the same in $$$ as a GTZ can cost 5-6k and an APEX will only fetch about 2500-4000 on th emarket at the moment.
Postby Tru3no20v » Fri Jan 13, 2006 4:57 pm
sweet, yeah thats pretty much along the lines of what i was thinking, if i was to do say s/c the 20v would the only parts be pistons for internal work? yeah i got told at work theres nit much between a 4agze and 4age 20v. And keeping the 20v i have has only done 140,000k's and id still have VVT and 20v if those are befinfits to worry about in the fist place.
Have any idea tho if its safer to turbo a 4agze rather than my car?
thanks for your info aye
ae82 fxgt corolla
Tru3no20v
Postby Mr Revhead » Fri Jan 13, 2006 5:32 pm
the pistons are the only internal part needing change.
there is a bit between a 20v and a 4agze. torque is everything and the 20v is seriosuly owned by the 4agze in torque.
the only time the top end of the 20v would be an advantage is on a fast flowing track. even then id take a good driver
a 4agze would handle turboing alot better than a stock 20v.
remember that if your turboing or s/c a 20v you MUST change the ecu and injectors etc
Postby Tru3no20v » Fri Jan 13, 2006 11:25 pm
Awesome thanks for your help revhead, yeah im looking stonger at the idea of finding a gtz then start mods on that, which is proving to hard to haha, so yeah cheers for that
ae82 fxgt corolla
Tru3no20v
Postby Crucible » Fri Jan 13, 2006 11:38 pm
Mr Revhead wrote:a 4agze would handle turboing alot better than a stock 20v.
GTE GTZ and N/A Bonnet would be nice and stealth (-:
Crucible
Real Life Mechanic
Postby IH8TEC » Sat Jan 14, 2006 12:01 am
haha i've thought about that, but haven't come across a cheap bonnet yet :lol:
Postby Tru3no20v » Sat Jan 14, 2006 1:00 am
haha it would take a few of the hondas around here for a good ride i cn tell u tht. there cocky as
ae82 fxgt corolla
Tru3no20v
Postby EVLGTZ » Sat Jan 14, 2006 5:22 pm
been there done that.
went back to me s/c bonnet as couldn't stand it looking like a 20v :lol:
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby ROBODISCO_20v » Sun Jan 22, 2006 1:27 pm
A set of mild cams, up the compresion a bit & get aftermarket ECU or piggy back fuel & that'll liven the silver top up. You should get about 150hp at the flywheel.
Other wise drop some ZE pistons in it, bolt on a turbo, programable ECU & you'll leave GTZ's for dead. HP will depend on boost level. 200hp easy i would say
ROBODISCO_20v
