MR2 turbo owners, please help
Postby Malcolm » Tue Jan 10, 2006 5:46 pm
As some of you may remember (but most probably don't), my MR2 had a strange dipstick problem, where the oil wasn't showing on the dipstick despite there being nearly 4L of oil in it. While tearing apart the motor, I discovered the cause. Someone has replaced the dipstick with one that is way too short! It's barely longer than the dipstick tube itself.
Anyway I need someone with a 1990-93 MR2 turbo to measure the length of their dipstick, from the Full mark to the cap/seal that sits at the top of the dipstick tube. Alternatively if someone has a spare I would gladly take it
Postby flygt4 » Tue Jan 10, 2006 5:58 pm
hehe my mate had a similar problem on his evo , later model dipstick didnt go through the hole properly , bent and went onto a little tray bit and got covered in oil making him think it was full. ended up running it dry and rooting bearings :oops:
flygt4
Postby IH8TEC » Tue Jan 10, 2006 6:04 pm
i had the same problem, then dad (aircraft tech for 28years) suggested put vivid on the stick, put it in and the oil actually stuck to it, because the oil wasn't giving me a reading on the stick
Postby Dell'Orto » Tue Jan 10, 2006 8:05 pm
Bang on 14", about 35.2mm
Postby Akane » Tue Jan 10, 2006 8:56 pm
Poor you.
I had a spare stick, which i promptly bent the tip into a U shape hook so I can use it to fish things that fall into the SW20's engine bay
<3
Postby Malcolm » Tue Jan 10, 2006 11:58 pm
thanks Brad.
Kenny, did you do that just now, after reading my message so as to spite me? :cry:
Postby RomanV » Wed Jan 11, 2006 1:54 am
If the NA ones are the same, you can have my old one. :)
Postby Akane » Wed Jan 11, 2006 2:54 am
All_Fours wrote:Kenny, did you do that just now, after reading my message so as to spite me? :cry:
ah, I did it ages ago, when I replaced my engine.
Postby Malcolm » Wed Jan 11, 2006 12:03 pm
could you measure it Dave? See if it's 14" or 352mm?
Postby RomanV » Wed Jan 11, 2006 12:51 pm
All_Fours wrote:could you measure it Dave? See if it's 14" or 352mm?
8O
Sorry, I can tell you right now, that it definitely AINT 14 inches.
Unless you're talking about the dipstick, in which case I will measure it when I get home. :P
Postby Malcolm » Wed Jan 11, 2006 1:00 pm
:lol: haha ok thanks
Postby RomanV » Fri Jan 13, 2006 8:38 pm
310mm. :?
Edit: That was from the very end of the dipstick to the plug, so the distance you requested would be even shorter than that.
Postby Malcolm » Fri Jan 13, 2006 8:45 pm
I think that might mean I have an NA dipstick, because that's about the same length as mine
