by KE20 » Thu Jan 19, 2006 6:00 pm
i made nearlysolid engine mounts when i put a 3sgteintomy ke20. i used the front swingarms from a mr2?(cant quite remember) they are cast iron, ground them flat and drilled some hills, bolted to the bolt, then made mounts off the x-member for them to bolt to. engine had 5mm max of movement,you could never realy see the engine movein engine bay, only thing was i keeped splitting the fuel tank cause the car kept twisting. when i crashed at taupo, only the dizzy broke, and thats cause it stuck throught the firewall when i did the conversion. but i didnt notice any vibration or anything. im currrently solid mounting my 1jzgte in my chaser, but this will be all soild steel.
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
