errr....see above
i wont be launching at all due to fear of gearbox munch-age!
still looking on the bright side if i do destroy the box it will give me the excuse to get a 6 speed unit in and go for some reasonable power upgrades
Ako wrote:diss1dent - does your car have tha adjustable centre diff? See if you can set it to 50/50 locked or however it works in those, your car was spinning up the fronts only in a big way last time you raced.
Graphite wrote:Think i'll do 3x Hard out runs with redline launch.. then take it easy for the DYO, although i find it hard it get off the line well without doing a hell launch, it always bogs down, or i slip the clutch too much and it smells bad.. lol
Ako wrote:Are you going to change gears really slowly as well then? I've seen more subbies kill off gearboxes from a snap shift to second or third than I have launching off the line.
Return to Christchurch / Upper South Island Region
