2e and 4e gearbox compatibility
Postby 20v_rollaboy » Wed Jan 18, 2006 8:36 pm
hey people, just wondering if a gearbox from a 2e would work on my 4efte?
20v_rollaboy
Postby Vertigo » Thu Jan 19, 2006 8:43 am
dont see why not, they are both e series engines.
TVIS just kicked in, yo!
Vertigo
Postby diss7 » Thu Jan 19, 2006 9:16 pm
It will bolt up but you'll need the 2e cvs, which are weaker.
Just get a 4e box, they are cheap anyway.
diss7
Postby 20v_rollaboy » Thu Jan 19, 2006 11:21 pm
does anyone know where i can get a cheap one from?
really need to get one for the wagon
20v_rollaboy
Postby Stu- » Sat Jan 21, 2006 12:55 pm
diss1dent wrote:It will bolt up but you'll need the 2e cvs, which are weaker.
Wrong, 4e cv's work with a 2e box (I've got them on my 1e for example) so it doesn't really matter as long as you have matching shafts. The inner cv spline count is the same for most of the c ceries boxes. You are right however that the 2e cv's are smaller and slightly weaker than the 4e units. I orginally had them in my 4agte without any problems so should hold up to a stinky old 4e :D
The 2e boxes (c150 or c152 if its the turbo s version) are a bit weaker thou, the internals are smaller (especially the diff) but the ratios are better. Try to find a turbo s box over a normal 2e one. As long as your not doing huge standing start 2nd gear antilag clutch drops you should be right, just have a spare kicking around against the day the internal parts of the box decide to become external parts.
Project Thread
Stu-
