silvertop qtb's on 3sge
Postby phrogmodz » Wed Jan 18, 2006 9:09 pm
im considering making a manifold to fit
silvertop quad throttle boddies on the 3sge
dose anyone know if the standard computer will
run with the 4ag tps and acv?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby RomanV » Wed Jan 18, 2006 9:19 pm
You wont get quads running just with the standard computer.
Or if you do, it will run like a one legged dog, use heaps of gas, and be significantly worse than when you started.
Postby Mr Revhead » Wed Jan 18, 2006 9:20 pm
why not? they're MAP sensor arent they?
not sure bout the tps though
Postby RomanV » Wed Jan 18, 2006 9:28 pm
Yes, they are MAP sensored...
But its the TPS signal....
Quads that are 5% open let in more air than a single throttle that is 5% open....
Which will no doubt confuse the hell out of the ECU.
I suppose it might not matter at WOT though....
Just make sure you floor it everywhere. :lol:
Postby atmosports » Thu Jan 19, 2006 4:59 pm
I can do a 3sge side draft manifold & then some adaptors to fit 20V tb's onto a side draft flange if that's off any help with regards to a manifold, the only hassle being the 3sge manifolds I've got are quite long like 125mm from flange to flange from memory that's just for th head flange to the side draft flange then you'd need to add adaptors & tb's, so if it's going into an MR2 from what I've been told you'd need a reasonable short manifold as for fitting in any other applications I have no idea.
atmosports
Postby phrogmodz » Thu Jan 19, 2006 8:23 pm
cheers for the info guys
ive done the conversion into a
cr21 townace and im looking for the easiest
way to make the inlet fit, wont be with quads though
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Mr Revhead » Thu Jan 19, 2006 8:43 pm
:lol: you put it where?! lol much better than a 2c anyway!
Postby phrogmodz » Thu Jan 19, 2006 8:55 pm
im having a hard time adjusting
from all the modifyed cars iv
had to a family vehicle
this is my way of dealing with it
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Mr Revhead » Thu Jan 19, 2006 8:56 pm
i hope your making suspension mods as well! 8O
Postby phrogmodz » Thu Jan 19, 2006 9:03 pm
nothing will be standard
within reason :?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby RomanV » Thu Jan 19, 2006 10:13 pm
phrogmodz wrote:im having a hard time adjusting
I salute you Sir! :D
Postby ROBODISCO_20v » Sun Jan 22, 2006 1:10 pm
Karl @ Garage Dori made a set of silvertop ITB's for a 3SGE. Get in contact with him if you need any help
ROBODISCO_20v
Users browsing this forum: Bing [Bot] and 31 guests
