Chickenman wrote:What is it exactly?
Some cars need to be raped off the line because they have all of 110 hp and some need a bit of.. . . finesse.
If you haven't found out by now.... what kind of boyracer are you?
mr pad wrote:Practice.
Ako wrote:They're all lying.
Use the factory launch controller - its set at around 7 - 8000 on the majority of cars.
Right foot on the ground, sidestep the left one. Easy peasy.
fivebob wrote:Best way to launch is redline, drop the clutch, order and fit a new clutch, or if your tyres are not up to scratch then order and fit new tyres. Repeat the process until your bank account is empty
All_Fours wrote:best way to launch? Get a GT4 with lots of power and a good clutch. Rev to 6,000rpm, sidestep off clutch - 1.7 60 foot
