Quad Throttle Body swap
Postby fx gt » Mon Jan 23, 2006 7:34 pm
after hearing of some Quad Throttle Bodys for sale im wondering if they will fit straight onto my 1v red top 4aGE,also can you get many gains out of putting them on?
fx gt
Re: Quad Throttle Body swap
Postby Malcolm » Mon Jan 23, 2006 7:40 pm
fx gt wrote:also can you get many gains out of putting them on?
Definitely - the aftermarket ECU you buy to run the engine with the quads should unleash a few extra horses :D
Postby fx gt » Mon Jan 23, 2006 7:43 pm
do u HAVE to have a aftermarket ecu to run em?
fx gt
Postby suberimakuri » Mon Jan 23, 2006 7:48 pm
this is going to become like club4ag.
itb's + aftermarket ecu.
otherwise your motor will blow up from excess fuelling.
suberimakuri
Postby RedMist » Mon Jan 23, 2006 8:00 pm
And they wont just plug up to your 16 valve.. you'll either need to create or buy an adaptor.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby BBBrad » Mon Jan 23, 2006 9:59 pm
Talking quads. I know that alot of aftermarket tuners do not like them. I hear the problems of poor vac signals etc. Im setting up some quads at the moment on a custom manifold. Any tricks I should know of? It seems that from the info ive read you are best to have a single vac area/container fed by all 4 runners(that you take your vac signal off), and also having balance pipes in between the runners.
Sound about right?
My new car...99 mr-s
BBBrad
Postby suberimakuri » Tue Jan 24, 2006 9:55 am
they are hard to tune relative to single throttle.
best for me has been 3 runners tee'd together with a dampener. (I don't care for balance tanks/bars/whatever).
1 runner fed to brake booster.
suberimakuri
quads
Postby Celica RA45 » Tue Jan 24, 2006 6:19 pm
or karl you can just run the quads off the tps and run the map to atmospere like i do
Celica RA45
Postby BBBrad » Tue Jan 24, 2006 6:29 pm
This dampner. Is that the little unit sometimes screwed into the manifold that the map sensor feeds off?
BBBrad
Postby suberimakuri » Tue Jan 24, 2006 6:48 pm
little round dampener.. common on anything with emissions gear on a carb...
not all are the same.
suberimakuri
