anyone have a redtop dizzy or 4agze CAS and can take a pic ?
Postby gdsup » Wed Jan 25, 2006 8:19 pm
Hey all,
if possible can someone take a pic of the cam angle sensor / pick-up on a smallport 4age redtop, or a DLI ( late ae92 or ae101 ) 4agze
just wanting to compare with the 20v
gdsup
Postby Caveman » Wed Jan 25, 2006 8:42 pm
This is redtop small port. has different inner workings than 4agze but same outputs to ecu so works the same.
another pic
Caveman
Postby gdsup » Wed Jan 25, 2006 8:56 pm
cool thanks heaps, do you know if the tooth wheel has 24 teeth as well ?
gdsup
Postby Lloyd » Wed Jan 25, 2006 9:52 pm
GZE CAS is identical to the Silvertop, just gotta chop the wires and wire them back up to the new setup. From memory 2 colours were the same and you swap the other 2, but I cant remember colours :P
Postby QikStarlie » Wed Jan 25, 2006 9:59 pm
yeh same shit just looks diffrent. E series engines also go from the old type pickup (like redtop) to the same setup 20v.
both old and new type work just the same, as i swap my linkplus between 5e(same pickup as 20v) and redtop 4age. using the same config..
also had new type pickups working on an old type standard ecu..
QikStarlie
Postby Caveman » Wed Jan 25, 2006 10:03 pm
gdsup wrote:cool thanks heaps, do you know if the tooth wheel has 24 teeth as well ?
Not sure, will try to remember to count them tomorrow.
It still amazes me how much people pay for the gze cas.
Caveman
Postby gdsup » Wed Jan 25, 2006 10:10 pm
ok heres what i've found off club4ag
AE92 4AGZE ( DLI )
G- = white
NE = Red
G2 =black
G1 = green
silvertop 20 bean
G- = white
NE = Black
G2 = Green
G1 = red
so looks like just a case of switching the wire between the three of them, from memory the wire colours vs codes are different between ae92 dli and ae101 so this could be the reason you only had to chop and move 2 HRT ?
gdsup
Postby Lloyd » Wed Jan 25, 2006 10:31 pm
Or maybe I just put the G1 and G2 around the other way and put the leads on opposite coils. Who knows, it went :)
Postby matt dunn » Sat Jan 28, 2006 1:20 pm
FYI, ST185 has the same as the 20V also.
Postby gdsup » Wed Mar 01, 2006 10:35 pm
It works, I just matched the wires off the 20 v dizzy/ cas into the DLI 4agze ecu, turned key sweet
gdsup
Postby strx7 » Thu Mar 02, 2006 6:14 pm
matt dunn wrote:FYI, ST185 has the same as the 20V also.
2JZGE is the same too, just rotates the other way from an ST185
I'm pretty sure the ST202 3SGE dizzy is the same aswell.
Postby vvega » Thu Mar 02, 2006 10:09 pm
so is the 185
vvega
Postby SpeedRacer » Tue May 16, 2006 4:00 pm
sorry to bring out an old post but i can use a 20v, st185, or red top small port cas on my 4agze? just checking thats all
Sinister Sleeper 35
SpeedRacer
Postby Grrrrrrr! » Tue May 16, 2006 9:27 pm
Mods: maybe this should be in Tech Section?
Grrrrrrr!
Postby matt dunn » Wed May 17, 2006 12:12 am
SpeedRacer wrote:sorry to bring out an old post but i can use a 20v, st185, or red top small port cas on my 4agze? just checking thats all
Anything you can physically fit and get to rotate should be able to made work,
Postby Caveman » Wed May 17, 2006 12:40 am
Yep the smallport one will fit the easiest.
Its good you dug up an old relevant thread instead of starting a new one. Shows people are actually searching.
Caveman
