Santa's Racecar Alarm
Postby Santa'sBoostinSleigh » Thu Jan 26, 2006 8:36 am
ok so i want my racecar to stay mine, it will have a fair amount of moohlah poured into it and i dont want some little fcuk to come think its theirs...
anyway, what would be a good alarm to install?
what i woudnt mind doing is if someone can give me a mean deal on the alarm unit, and then when im doing the conversion, wire the alarm in myself :)
suggestions/thoughts?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby wde_bdy » Thu Jan 26, 2006 10:02 am
Hiding stuff in a stripped out racecar is the biggest problem, makes it very easy to find +12v and feed power to ECU, fuel pump, starter etc. Try cutting sensor, injector etc circuits and hide the alarm brain very well or the whole exercise will be pretty pointless.
Callum
wde_bdy
Postby Malcolm » Thu Jan 26, 2006 10:16 am
make some sort of plug in harness adapter on the engine loom/ecu so that you can quickly remove it and the ecu will no longer be plugged in to anything. This will make life very difficult for someone wanting to take the car.
Postby Santa'sBoostinSleigh » Thu Jan 26, 2006 1:05 pm
yeah the immobiliser side of things becomes difficult, but if i fit a freaken loud siren to the doors/glassbreak etc, at least that becomes a partial deterrant
Santa's Mega Sale
Postby Jazza » Thu Jan 26, 2006 4:44 pm
Another thing that helps is having a fcuking loud internal siren... One inside the car, one under the hood. And a battery backup too so if one if cut the battery one turns on..
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby DeeCee » Thu Jan 26, 2006 4:50 pm
some of my friends use house sirens ;)
GT Four Adovansu
DeeCee
Postby Punter » Thu Jan 26, 2006 5:04 pm
DeeCee wrote:some of my friends use house sirens ;)
Those litle tiny screamers?
Man those things are loud.
Punter
Postby MINTFX » Thu Jan 26, 2006 5:36 pm
Seems like a good idea. Ill be mounting two of the loudest possible sirens inside my next car.
MINTFX
Postby Jazza » Thu Jan 26, 2006 6:16 pm
I got 3 sirens in mine. 2 external (one is battery) and 1 internal... When those things go off you know all about it...
Jazza
Postby Malcolm » Thu Jan 26, 2006 6:49 pm
I had 2 119dB and one 122dB piezo sirens in my Celica, the big one was in the aircon vent above the stereo and the two little ones were in the back, by the parcel tray, pointing forwards. Absolutely, brutally painful to be in there with them going off :D
Postby Blackrazor » Thu Jan 26, 2006 9:06 pm
You'll find that most alarm guys wont sell most decent alarms by themselves, as they are only covered by any sort of warranty if installed by an approved agent anyway.
Boring Sig
Blackrazor
Postby Santa'sBoostinSleigh » Thu Jan 26, 2006 10:05 pm
Blackrazor wrote:You'll find that most alarm guys wont sell most decent alarms by themselves, as they are only covered by any sort of warranty if installed by an approved agent anyway.
yeah i figured as much - dont really care about the warranty
thats why i thought id ask here and see if anybodys got a hookup ;)
Santa's Mega Sale
Postby Blackrazor » Thu Jan 26, 2006 10:35 pm
Santa'sBoostinSleigh wrote:yeah i figured as much - dont really care about the warranty
You can get decent dual immobilisers alarms from the likes of AVS for around $350 fitted anyway, why bother mucking around? ;)
Boring Sig
Blackrazor
Postby Santa'sBoostinSleigh » Fri Jan 27, 2006 9:34 am
what if i wanna do it myself?!?! HUH?!?! ;) :D
Santa's Mega Sale
Postby DeeCee » Fri Jan 27, 2006 10:39 am
if you don't care then get one of the steelmate paging systems from tardme.. they have some pretty good features
GT Four Adovansu
DeeCee
Postby Blackrazor » Fri Jan 27, 2006 10:44 am
Santa'sBoostinSleigh wrote:what if i wanna do it myself?!?! HUH?!?! ;) :D
<taps his dick on SBS's forehead>
BOOYAH!
;) :lol: <hides>
Boring Sig
Blackrazor
Postby Jazza » Fri Jan 27, 2006 1:24 pm
Its kinda costy, but depending on what you want.. Meridian alarms (and several others) will pay your excess if your car gets broken into with one of their alarms in it. PM me if you want more details.. ill be gone for the weekend though.
Jazza
Postby KinLoud » Fri Jan 27, 2006 10:34 pm
Hitch up a couple of smoke alarms inside the car...
Use the test function.
Wire a door switch across the test switch... open door... deafened!!!
I haven't thought about how you would get into the car yourself without them sounding but it's the start of a cheap and loud alarm system, he, he, he.
Ken
Ham
021 408 863
Postby barryogen » Mon Jan 30, 2006 1:03 pm
KinLoud wrote:Hitch up a couple of smoke alarms inside the car...
technology is your saviour Ken...
a simple little RFID to kill the power when you're within say 10ft.
Will tinker with this when I get home.
barryogen
2ZZ Guru in training
Postby Stealer Of Souls » Mon Feb 06, 2006 9:11 pm
barryogen wrote:technology is your saviour Ken...
10ft RFID?! 8O
My answer...
Reid switch, latching relay with a reset button...
Cheap and nasty, but does a good job. Uniden alarms. Fit with extra sirens, immobilisers, and your away... Hook the alarm to the horns while you're at it...
Again. 12V SLA, little diode-relay system and you've got a 7AH battery back up for the whole alarm system... Now... How to hide it in a race car...
Answer? Small non-descript metal box?
'86 AE85.5 Levin
Stealer Of Souls
