Kov wrote:Other idea was T3/T4 hybrid which obviously has been done before, what kind of revs would a combination like this hit full boost and what kind of hp could it handle?
(spose there's too many variations of T3/T4 to say really huh)
any help much appreciated!
True-No-Turbo wrote:Kov wrote:Other idea was T3/T4 hybrid which obviously has been done before, what kind of revs would a combination like this hit full boost and what kind of hp could it handle?
Im going down this road as I want good top end power. Using a T3/T04E VBAND "O" TRIM .70a/r Div/Tang. (550 Hp Turbo). Its on a Custom Split Pulse Mani, This had been modeled directley off Bazdas Setup, He saw Full boost at 4800rpm on a low comp ze, Hopefully Ill see approx 4300 - 4500 on my Hi comp ze. I realise I will need to upgrade ECU, injectors etc to get the full potential out of this Turbo but will be only running relatively low boost until then.
Bazda says the Top end power from this setup is awesome![]()
TNT
vvega wrote:dribble dribble
lol
strx7 wrote:a T28 from a GTiR will get you your target HP
Adamal wrote:
Are you sure about that? He said he's looking for 250-300hp, and the GTi-R isn't 250hp stock and the SR20 is a 2 litre..... The S15 uses a BB T28 (almost the same as the GTi-R one) and makes 250hp stock... But again, is the same SR20.
We're talking about an engine that's 400cc smaller as well... You'd have to seriously work the engine to pump the boost up to make that sort of power with that turbo, wouldn't you?
