Kp60 Starlet Conversion
Postby DXROLLA » Sun Jan 22, 2006 1:42 pm
Hey ive just got me a 1983 Kp60 Starlet (2 door) and was wondering i have me engine (4K) that i have been doing up for me DX would this be sweet to bolt into the starlet which has a 2K and also use the standard diff out of the DX or are they the same diff? Oh and the DX is a 1982 KE70 sedan.
DXROLLA
Postby z|gen » Sun Jan 22, 2006 2:48 pm
engine will bolt straight into the starlet.
depending how "worked" the 4K is, the diff should stand up to it.
AE91 SUPERCHARGED COROLLA
z|gen
Postby spencer » Sun Jan 22, 2006 7:35 pm
z|gen wrote:depending how "worked" the 4K is, the diff should stand up to it.
Depends how much of an animal you are to how much the diff will take! if its a drop hatch it will have the same size diff head as a ke70
spencer
Postby DXROLLA » Sun Jan 22, 2006 7:40 pm
Oh ok i was just wondering about the diff ratios as in the 2K it seems to b reevin pretty hard at 100kph or is that more to do with the 4speed box?
DXROLLA
Postby DXROLLA » Mon Jan 23, 2006 4:46 pm
Also as far as cheapish break upgrades go what sorta thing is best to do and what sorta costs? as the breaks at the mo to put it nicely are $&#$% SHIT!
DXROLLA
Postby Loudtoy » Tue Jan 24, 2006 6:58 pm
What you need to get the brakes updraded for?? How hard are you going with this 4k of yours. Some competition pads and linings should do it, and changing the brake fluid would be recomended as well.
If you really want to change the brakes get hold of some ke30 front struts including the brakes (rotor, calipers the whole lot) change the lower arm ball joint on your starlet to ke 30 ones and bolt it all up, bleed brakes and front is done. Otherwise if you can do some fabricating yourself you could put just about anything you want to on there :) Or if you have a big wallet same applies.
As for the reving thing as much to do with the box as anything, if you still have a standard diff that is. If it's been changed it may be the diff but i doubt it is. PS 4 speed boxs are stronger than 5's
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Jebus » Tue Jan 24, 2006 7:03 pm
Loudtoy wrote: PS 4 speed boxs are stronger than 5's
Bull.
Jebus
Postby Low_Aa63 » Tue Jan 24, 2006 7:10 pm
Loudtoy wrote:PS 4 speed boxs are stronger than 5's
bahahahah
anything this man ever says from this point onward is lies
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby DXROLLA » Wed Jan 25, 2006 6:54 pm
Well the breaks at the moment bearly stop ya at 50k quikly let alone 150 or wateva coming up to a corner, the pads and break fluid upgrades sound good what about the rear drums is there much point doing anything to them?
DXROLLA
Postby z|gen » Wed Jan 25, 2006 7:13 pm
unless your doing it as a track car..why would you be doing 150km?
if your wanting to go serious, think about upgrading your diff to a ae85 one, and your front brakes to ke70 - bit of work involved, but will stop you.
z|gen
Postby RomanV » Wed Jan 25, 2006 7:15 pm
The reason that people prefer 4 speed boxes for their 'race' starlets is because they are lighter, and also because they dont really need a 5th gear for gravel sprints etc.
Postby sk1dlet » Wed Jan 25, 2006 7:17 pm
if you want to upgrade your front's have a look at this conversion
http://au.geocities.com/quibel_nz/Evo3_02.htm
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby DXROLLA » Thu Jan 26, 2006 6:49 pm
Yes it is going to be a track car but will also be used on the road, i have some struts sitting here they are supose to be of a ke70 but dont actualy fit so i wouldnt no the disks are the same as the ke70s so could i just take the disks and calipers of them and put them in the starlet? and is there much point upgradeing the rear?
DXROLLA
Postby Frosty » Thu Jan 26, 2006 11:57 pm
The reason your brakes are usless is more likley Shocks. Bad shocks = bad brakes. As for brake upgrades try semi race pads (Ive had luck with EBC Green pads) and the best brake fluid you can afford. There are heaps of semi race cars out there with this system and yes you can get race compounds for your drum brake rear. Good luck.
Project 73 RT-87 Corona Wagon, 1G-GZE & W55.
Project 67 Anglia Van 1500 & Escort Box.
Beater TT-132 Corona Sedan.
Frosty
Postby RS13 » Fri Jan 27, 2006 3:01 pm
I dropped a 4K into my old KP61, the difference is incredible! Still had the 4spd box off the 2K, took skid after skid after skid.. and still came back for more. I had to swap the 2K dizzy into the 4K, only because the 4K-J I used was from a KP61 Sprint, with electronics.. but the end result will blow you away!
I used the standard brakes, found them to be more than adequate, (it really isn't much car to stop!), so throw some new pads on, give them a fluid change, perhaps get some new front shocks.
RS13
Postby DXROLLA » Fri Jan 27, 2006 7:17 pm
Sweet thanks so loks lyk il do a pad an fluid upgrade and the shocks will be upgraded when its lowered ect,
DXROLLA
Users browsing this forum: No registered users and 34 guests
