Intercooler help..
Intercooler help..
Postby RS13 » Sun Jan 29, 2006 9:39 pm
hi guys
I'm after an intercooler, has to be good for around 300hp, and be shaped roughly like:
Does anyone know of any factory cars with something similar? I need it to have both inlet and outlet at the same end, I'm trying to use as little piping as possible, as most fmic setups I've seen have the piping down/across/in front of the motor, basically doubling back on itself.. which I'd imagine would be bad for throttle response/lag.
Any help = much appreciated. Cheers!
RS13
Postby Dell'Orto » Sun Jan 29, 2006 9:48 pm
MA70 Supra intercoolers are shaped like that, not sure how well they'd flow though...fairly sizable units though.
Postby Lloyd » Sun Jan 29, 2006 10:34 pm
Yeah, was thinking the same. They're not a bad size cooler for a factory one. What engine is it for?
Postby Malcolm » Sun Jan 29, 2006 11:03 pm
yes, ma70 ones are like that, if it's for a high-ish power application you could run 2, as some mk3 supra guys do
Postby loose_unit » Sun Jan 29, 2006 11:07 pm
2 x series 4/5 coolers welded together with custom tanks would easily flow enough for 300HP and could be arranged with in/out like you have above.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby THA SHZ » Mon Jan 30, 2006 9:19 am
go custom made wood be good , pm evil si bout it 8)
THA SHZ
Postby Silent Knight » Mon Jan 30, 2006 11:06 am
I've got a stock 1JZ intercooler from a JZZ30 if you want to try that?
I'll get some pics up tonight when I get home...
Silent Knight
Postby RS13 » Mon Jan 30, 2006 7:39 pm
Shit yeah mate, if you could supply a pic and dimensions, that would be grand!
RS13
Postby Si » Mon Jan 30, 2006 10:49 pm
the older ma70 ones apparently have a massive pressure drop
Current: , '96 SubaruImpreza
Si
Postby RS13 » Tue Jan 31, 2006 6:36 pm
^^^^ That is exactly what I'm after.. is it custom or factory?
RS13
Postby blackmk3 » Tue Jan 31, 2006 7:03 pm
the standard auto ma70s on standard boost run 6.8psi and have a 3.4psi pressure drop thru the cooler....id hate to even imagine what the turbos pushing when you put the boost up :?
Mk3 MA70 Supra
blackmk3
Postby Si » Tue Jan 31, 2006 9:41 pm
That is a spearco replica bolt in MA70 cooler :P
399$ us$.
im sure you could get a custom one made here for less than that.
Si
Postby Silent Knight » Tue Jan 31, 2006 9:45 pm
RS13 wrote:sh*t yeah mate, if you could supply a pic and dimensions, that would be grand!
PM me your e-mail address and I will send you a picture of the Intercooler.
Silent Knight
