I'm after an intercooler, has to be good for around 300hp, and be shaped roughly like:
Does anyone know of any factory cars with something similar? I need it to have both inlet and outlet at the same end, I'm trying to use as little piping as possible, as most fmic setups I've seen have the piping down/across/in front of the motor, basically doubling back on itself.. which I'd imagine would be bad for throttle response/lag.
Any help = much appreciated. Cheers!
