Which Engine Management System for ST 185 celcia gt4?
Postby GT4PWA » Mon Jan 30, 2006 9:11 pm
After reseach on the net, what engine management system woudl you reccomend for a ST185 gt4.
Everyone on the net claims their product is best so im wanting some advice from someone who has been there and done that on these cars.
Im willing to spend up to 5k on the management system as i know it will be money well spend for when the new engine arrives. I also want to know there are places that know how to install and tune these things properly
Its purpose is a quick street car that drives well but can handel the pressure or meri meri or pukekoe.
I hear link is the common system but are they suitable for my car and want im wanting from my car? keeping in mind im looking for around 500hp at the wheels?
GT4PWA
Postby vvega » Mon Jan 30, 2006 9:17 pm
if youve got 5k....
motec
nothing else worth considering with that sort of budget
v
vvega
Postby GT4PWA » Mon Jan 30, 2006 9:25 pm
haha its up2 5k, just mainly value for money and keeping in mind the 500hp at the wheels figure. thanks for your feedback :)
GT4PWA
Postby Alex B » Mon Jan 30, 2006 9:27 pm
How much do you plan to spend to get 500hp atw?
Postby GT4PWA » Mon Jan 30, 2006 9:36 pm
enough so that im not blowing the engine and it is somewhat reliable. If possible id try to be able to control that HP from teh cabin so that 500hp only b used at meri meri or on the dyno. for day to day driving have it sitting at around 300-350.
GT4PWA
Postby strx7 » Mon Jan 30, 2006 9:37 pm
if you have 5K then get a Motec M800.
If you want to spend a bit less get something along the lines of an Autronic SMC2 or a Haltech E11.
Postby Alex B » Mon Jan 30, 2006 9:39 pm
so in other words enough to buy a much higher spec car :wink:
Postby GT4PWA » Mon Jan 30, 2006 9:43 pm
yea enough for a higher spec car....but i have always liked these cars and wanted to build one, i guess nows my chance
GT4PWA
Postby Malcolm » Mon Jan 30, 2006 9:46 pm
500hp @ wheels is a seriously massive number. You're going to need around 600hp @ the engine to reach that - which on a 3sgte is getting into very expensive territory.
The hydra nemesis seems to be a pretty good option - many of the extra features you'd use from a motec but a lot cheaper.
Postby Adydas » Mon Jan 30, 2006 10:06 pm
Race ya there.
Adydas
Postby GT4 20 » Mon Jan 30, 2006 10:07 pm
How about a Power FC? MR2 one should do the job :D
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby vvega » Mon Jan 30, 2006 10:27 pm
[hrdtshtwerh
vvega
Postby fivebob » Mon Jan 30, 2006 10:44 pm
strx7 wrote:if you have 5K then get a Motec M800.
No, get the M400 and save yourself $1000 :wink:
Postby matt dunn » Mon Jan 30, 2006 11:18 pm
I wired a linkplus into an ST185 a while ago,
it runs aftermarket rods pistons etc but with std head and cams.
I run it on a Linkplus and they are more than happy with the results at around 200kw atw on road fuel (96)
But that is nowhere near what you are wanting to go and get.
If you have enough cash to get that reliable power out of an ST185,
then you have the cash (as stated) to go motec.
Matt
Postby Akane » Mon Jan 30, 2006 11:38 pm
With those mild mods get a Link or something.
Or if you do want to spend $5k, then Motec.
Postby IH8TEC » Tue Jan 31, 2006 12:03 am
talk to bbbrad, he is gona be making alot of power, and runs a linkplus i think, it's in a mr2 i know, but motor still pretty much same,
Postby GT4PWA » Tue Jan 31, 2006 12:43 pm
cool thanks for all your help there. Im going to save for the MoTeC now i see turbo cars in penrose stoke these ECUs is there anyone else ina uckland who can tune as well?
GT4PWA
blah
Postby Ganjasaur » Tue Jan 31, 2006 12:44 pm
I would suggest going to talk to John Butler at Tuning and Performance. He will give you a good honest answer.
Address:
8 King St
Hamilton
Phone number: 0-7-846 6546
A friend of mine recomends a Motec M800 or Autronic SMC2. Having worked on Rod Millens hill climb celica and many other high powered 3sgte engines i would say he will be on the money.
Ganjasaur
Postby Ako » Tue Jan 31, 2006 1:10 pm
Agreed with ganjasaur. Either go for the motec, or an autronic. Both are very very capable units. If you're serious about wanting 500hp+ I wouldn't try cutting corners on the ECU.
And make sure you get the right person tuning it!
Ako
Postby kilowatts » Tue Jan 31, 2006 5:41 pm
Randell edgell will supply an autronic ecu fitted and tuned for $3800 .
current rides: 1994 toyota hiace, 1998 toyota hiace, 1998 toyota supra/na,2000 toyota caldina gtt,(1993 toyota fxgt has just been sold)
kilowatts
