All_Fours wrote:just wondering here 5B - are you entirely pulling those numbers from your arse or did you think of the things that would be needed to be done to safely get you to each level? maybe it would be worth spending a little time to put together a brief list of what would be needed for each power increment?
strx7 wrote:i'm targeting the 350-400hp mark with my GT-T powered ST185. And i'm planning on spending no where near those $$$ and that will include purchasing the ST185. I
fivebob wrote:$5-10k for the motor, get real guys that's 5-10k for the first motor which you will blow and then you start again doing it properly.
You want torque you need capacity.
Stroker Kit & Block work $8-12,000
You need a turbo that optimised for high boost at low Rpms. Turbo Kit $5-8000, Actually you could blow the whole $25k or more on a turbo to do the job, I know of one that has produced 600ft lb of torque @3500rpm in a 2 Litre motor but the cost was astronomical
You need cams, valves, springs etc and head work $3-5000
The Stock manifold will have to go, $1-3000
You'll need a good Intercooler but you should be able to go a bit cheaper if you do the fitting yourself $1-2000
Probably need to upgrade the cooling system, $1-2000.
You'll need a decent EMS to hold it all together, IMHO a link won't do you'll need a Motec, Autronic or similar $3-5000
You'll need a very good twin or triple plate clutch to transmit that torque, $1-4000
Then you'll need to upgrade the drivetrain if you're running on Tarmac, $1000 for axles alone, $3-8000 if you change the gearset.
Add in the labour and dyno time another $2-5000 maybe more.
total cost $25-54,000 and that's assuming it all goes right and you don't blow a motor. Time to go see a bank manager and extend the mortgage, or just go back to dreaming about it and mouth racing, far cheaper and easier
iownashittytoyota wrote:lookin for big horse power out ov a 3sgte, wot turbo, pistons, injectors
av people ad t best results with n wot power u makin?
factory clutch is getting left in there till it shits its self, any ideas on what i should replace it with when it does?
Users browsing this forum: Google [Bot] and 20 guests
