vvega wrote:rods are longer
block is taller
So you could use 4age rods? But have real low compression?
no_8wire wrote:vvega wrote:48mm on the caldena
v
This is refering to what?
agreedezy10s wrote:Pauter have a distributor in Australia? whos that Bazda?
I scored mine direct from Pauter America.
Hey Drifter4ag- the design of the piston would be horribly top heavy if you wanted to have one made to suit 4ag rods- looked at that with those carillo rods i had. And Rev is probably right to about actually getting theengine to turn over physically with that short of rod.(dunno for sure though as never botherred to try)
Unless you contributors are planning on making a 7agte similar to bazdas or Nick tee boones N/A version- just dont be silly with the rpm limit or boost limit and the std rods will be fine- do have a look through the club4ag site for the 7age/te/ze posts- there is a lot of interesting and helpful stuff there
no_8wire wrote:no_8wire wrote:o
Would any one with a compression calculator be able to tell me what the compression would be if I had:
Pistons: 4AG-ZE Supercharged.
Crankshaft: Standard 7AF-E
Conrods: Standard 7afe
Compression Ratio:?
