Truenotch wrote::P Bitching about the focus Matt?
pyro_sniper2002 wrote:So hows that focus matt?
Chickenman wrote:My corona would rev off the gauge(8k)
Revving to redline is also about putting the engine in the right place for the next gear, so changing at or just before the red mark on your tachometer is something that you should practice (preferably on a drag strip). None of this Fiiiiiiiiiiiiiiiiiiiiiiiiiiiiirst gear - 5TH stuff around town
Chickenman wrote:Revving to redline is also about putting the engine in the right place for the next gear
Adamal wrote:If you're meaning bouncing off the redline, then thats usually an ECU controlled fuel cut. Which is bad for EFI cars.
In carb'd cars, the fuel is still being supplied, the engine just can't rotate any faster.
Ako wrote:WRONG
you need to move your arm faster
no_8wire wrote:Leon wrote:Well, when we pull my bigport down to trace the knock, I can tell you what 18 months of clubsport use, much of it on or near the redline does to a 4AGE.
Got pics?
barryogen wrote:Ako wrote:WRONG
well ok then, but even when flat shifting it doesn't quite hit the magic point. maybe(probably) I need more practice.
