Im looking at ways to help with the spool on my 4agte. Its running a tvis manifold but no butterflies.
Is the Tvis system stand alone, as in no ecu control? I just need to know as my gze ecu obviously wouldn't have the output if there is one.
Stealer Of Souls wrote:TVIS has an ECU signal according to my haynes manual for the AE92.
Distrb wrote:i still have that complete tvis setup here gav if you require it
sergei wrote:just use RPM switch device from jaycar... (www.jaycar.co.nz browse the kits section)
sergei wrote:Here it is:
http://www.jaycar.co.nz/productView.asp?ID=KC5378&CATID
And here wich can do similar:
http://www.jaycar.co.nz/productView.asp?ID=KC5265&CATID
Users browsing this forum: Google [Bot] and 30 guests
