Q- for TE71/KE70 diffs some will know.
Postby gepsk8 » Mon Feb 06, 2006 11:54 pm
hey, i know of a rwd gl(te71) wagon with an automatic,
need to know if the diff will it fit into my mate's dx wagon(ke70)k series manual with no mod to the drive shaft? or does yoke need to be changed?
cheers for ne help.!!!!
gepsk8
Postby Wings_Alexander » Tue Feb 07, 2006 12:52 am
you will need to change the mounts to fit leaf spring. and you obviously know that since its from a te71 gl its not a t series diff (6.7 inch crown) it will only be an s series (6.3 inch from memory).
And youll need the part of the driveshaft that attaches to the diff because again from memory they are different to the k series item.
someone might be able to clarify.
Wings_Alexander
Postby fangsport » Tue Feb 07, 2006 12:42 pm
interesting...............is it a factory TE70 wagon??? with a leaf sprung rear?
if it is, count the bolts holding the head in and compare the overall size, chances are they will be the same, if so swap them over, the pinion flange should be the same.
fangsport
Postby Wings_Alexander » Tue Feb 07, 2006 8:02 pm
umm no they are different. a te71 wagon has s series and you ke70 will have u/b/x diff!!
Wings_Alexander
Postby fangsport » Tue Feb 07, 2006 8:35 pm
Wings_Alexander wrote:umm no they are different. a te71 wagon has s series and you ke70 will have u/b/x diff!!
never seen a TE71 wagon, so can't qoute, you obviously know of the vehicle.
as for d/shaft, you'll need one from an AE70/85 to go from K40/50 to S series rear.
fangsport
Postby fuel » Tue Feb 07, 2006 10:18 pm
Maybe he means a TE71 liftback? Which can almost look like a hatch wagon thing. There was also a 5 door TE71 liftback, but they were pretty rare and doubt he has one of them. I thought the TE71s only came in sedans, liftback and coupes.
The TE71 should be S series diff, with 8 bolts and 6.3" as mentioned above. It will have smaller axles than a AE85 S series. The TE71 GT has T series rear end with discs.
LOUD NOISES!!!
fuel
Postby fangsport » Tue Feb 07, 2006 10:36 pm
fuel wrote:Maybe he means a TE71 liftback? Which can almost look like a hatch wagon thing. There was also a 5 door TE71 liftback, but they were pretty rare and doubt he has one of them. I thought the TE71s only came in sedans, liftback and coupes.
i'm a bit curious as well. there is a TE72 wagon (USDM), but have never heard or seen one in these parts, but it would be cool to have a left-hook Toyota!!
fangsport
Postby gepsk8 » Tue Feb 07, 2006 11:14 pm
cheers, i think its not a t series diff then i just through it would be, its a 1984 gl wagon. just know where it is, haven't check out proply.
gepsk8
Postby AE85coupe » Fri Feb 10, 2006 2:29 pm
firend of mine has a te72 wagon, looks just like a dx, came out with a 12t engine in it
AE85 Trueno *For sale*
Details of car here
AE85coupe
