Changing Cambelt
Changing Cambelt
Postby 20v_rollaboy » Sat Feb 11, 2006 8:33 am
Im changing my cambelt for the first time, so is there any thing specific i should or shouldnt do??
Do I have to take the engine mount off??
And do I have to take the pulley on the crank off??
Thanks for any help
20v_rollaboy
Postby gordon77 » Sat Feb 11, 2006 9:31 am
yes and yes. i also did the crank and cam seals when i did mine. good time to replace all the other belts aswell and possibly even your water pump if u get carried away :)
crank pully is a cow to get off. i used the "put a half inch power bar and crank the engine over" method. worked a treat. but remember - only crank the engine over - dont start it. if u have an alarm put the imobiliser on so u dont start the engine.
What is RR?
gordon77
Postby Adydas » Sat Feb 11, 2006 11:44 am
There is a small list of parts you should do IMO
Water pump, Tensioner Idler Cam seals Crank seals Thermostat.
Or like myself go the hole hog and get the head rebuild ($250) for New Stem seals, acid bath check everythings good new cam cover seal etc all fitted.
Adydas
Postby 20v_rollaboy » Sat Feb 11, 2006 4:10 pm
Sorry should have said on my 20v
the cambelt came off real easy, I could pull it off with my fingers. I think the tensioner was stuffed, so i tried undoing the bolt that holds it on and it was real tight, so I put a bar on the end of the spanner and pulled, heard a crack, thought it had come undone, but instead found that I had cracked the bit of aluminium that goes over the crank and that the tensioner tightens on to.
How does this come off? Ive undone all the bolts and removed the gear, but it still wont come off
20v_rollaboy
Postby sergei » Sat Feb 11, 2006 4:59 pm
Is it me or it looks like you have broken the oil pump housing?
So in that case you will have to undo the sump and disconnect the oil pickup.
Pickapart is best place to get 20v oil pump for real cheap. unless you want to spend $200-$300 (not exactly sure how much, Mr Revhead will sort you out) on new item.
Postby 20v_rollaboy » Sat Feb 11, 2006 5:02 pm
so i have to take the sump off ay.
well ive got a spare engine that i can strip parts off from.
do i have to drain all the oil out of the sump or will it be ok if i just keep it upright?
20v_rollaboy
Postby Jebus » Sat Feb 11, 2006 5:04 pm
Drain it, it will take all of 3 minutes.
Jebus
Postby sergei » Sat Feb 11, 2006 5:37 pm
and sump is actually 2 piece sandwitched together
Postby rotorchiki69 » Sat Feb 11, 2006 5:40 pm
yea leaving the oil in will make a mess
rotorchiki69
Postby 20v_rollaboy » Sat Feb 11, 2006 6:38 pm
does anyone here have a pulley puller (gear puller) that i can borrow?
i managed to get the gear off my donor engine but its proving more difficult with the engine in the car
20v_rollaboy
Postby no_8wire » Sat Feb 11, 2006 6:59 pm
they are only about 20 from repco...but are cast iron... :x
If you cant get one off somebody...
no_8wire
Postby 20v_rollaboy » Sat Feb 11, 2006 7:29 pm
Anybody??
20v_rollaboy
Postby gazza_jay » Tue Feb 14, 2006 11:38 pm
far man you have had some hassles with your cambelt how many k's it done.. Ive done a couple cambelts on mine and never had any problems.. well tell a lie after the first cambelt done the vvt pully let go but apart from that its been allgood.
gazza_jay
Postby 20v_rollaboy » Wed Feb 15, 2006 12:01 am
Only reason i had problems was cus i stripped the tensioner bolt and then cracked the oil pump cover trying to get it off
But shes all go now :D :D
(Thanks to Sergei for helping to set my timing after i broke a bit off the gear :oops: )
Oh yea and the oil light hasnt come back on again
20v_rollaboy
