help with brakes and engine plz
Postby bluemaumau » Sun Feb 12, 2006 6:12 pm
ok im about to start the 4agte project.
the subject is a 1993 ae101 corolla wagon with a 4afe and front disks.
1. what is the best 4agze to put in? (in terms of performance and ease)
-my guess would be the ae101, but feel free to prove me wrong.
2. will i need engine mounts?
3. to obtain a cert for this conversion i will need a brake upgrade, will ae101 gtz or gt-apex 4 wheel disks be good enough?(a question for a certifier or sum1 whose done this conversion)
4. will ae101 gtz or gt-apex hubs(obviously with brakes)fit onto my wagon?
thank you 2 all that help with this project. :D
Postby bluemaumau » Sun Feb 12, 2006 6:18 pm
i found a 1991 gt-apex levin shell with brakes. - will these fit? anyone
Postby sergei » Sun Feb 12, 2006 6:20 pm
AE101 non SuperStrut will straight bolt on, otherwise no (AE101 GTZ brakes and 20v SuperStrut will not fit without modification).
AE101 GT APEX are same brakes as AE92 GTZ.
You don't need to change hubs, just swap rotors, calipers and brackets, if you are going to use 20v non-ss brakes or AE92 GTZ.
Best motor in my opinion would be a ECU/loom from MAP AE92 GTZ (later model) in combination with AE101 GTZ engine. That if you can find later AE92 GTZ loom.
Use engine mounts off GTZ.
Postby bluemaumau » Sun Feb 12, 2006 6:36 pm
sorry if i missed the point but i have dirty drums on the back at the moment so dont you have to swap the hubs over? so would a 1991 gt-apex levins 4 hubs fit onto my car?
Postby 20v_rollaboy » Sun Feb 12, 2006 7:06 pm
You only need to change the drummies, well thats what Ive done. The front discs are only a couple mm thicker.
And they will bolt straight on.
The long as bolt that holds the two arms onto the hub is a pig to come off, but it does. I had to use a combination on pressing it out and heating it up with a gas torch. Make sure you get the handbrake cable and all the bits for that as its different
20v_rollaboy
Postby THA SHZ » Sun Feb 12, 2006 9:28 pm
you may also find that the rear engine mount wont fit dependin on which type of box u use 8)
THA SHZ
Postby bluemaumau » Sun Feb 12, 2006 10:05 pm
well one of my front wheel bearings is $&#$% so ill just use all gt-apex hubs. + i gotta do my cv's cuz ther screwed too. lol (too much thrashing and handbrakes for the 4afe.
do 4ages use different cv's too 4afes?
Postby KinLoud » Mon Feb 13, 2006 1:03 pm
AE101 trueno brakes will bolt on (unless you have leaf springs, see below)
Rear brakes:
Does your car have coil springs at the rear? (some wagons have leaf springs).
- If it is coil spring...
Rear brakes - you will have to swap the hub, disk, caliper and handbrake cable across. The long bolts that connect the 2 track control arms to the hub can be difficult to undo/get out as they can get a tiny bit of rust where they go through the hub and they can stick real tight! Either:
1 - swap the whole rear subframe across (easiest in my opinion) or
2 - get crc and a hammer and a spanner. spray lots of crc, turn the bolt as you tap it gently out with the hammer.
Put a tiny bit of grease in the hub where the bolt goes through when you put it back together so that it will be easy the next time!
- If it is leaf spring at the rear... don't know what you will have to do... tell us when you do it!
Swap the brake bias valve across from the donor car so that it will give the correct pressure to the rear disk brakes.
Front brakes:
Swap the trueno hubs and brakes across if it is a 20v. Thicker disk, bigger wheel bearings.
Driveshafts have the same spline at the hub end on all AE101s
Have fun
Ken
Hamilton
021 408 863
Postby bluemaumau » Mon Feb 13, 2006 5:30 pm
thanks alot kinloud and 20v rolla boy. helpful shit. so the cv's are the same?
yes its a GL so it has coils. diesels have leaf springs.
jeez wouldnt it be a bit of a mission to swap the whole rear subframe, i never even thort about it!
Postby soopachargen » Mon Feb 13, 2006 6:44 pm
iv seen some petrol wagons on trademe lately with leaves in the rear... Revhead?
When in doubt, down and out.
soopachargen
Postby magweal » Mon Feb 13, 2006 7:42 pm
wouldn't the rear struts and brakes from a BZ-T bolt on same shape i don't see y they wouldn't
magweal
Postby 20v_rollaboy » Mon Feb 13, 2006 11:43 pm
magweal wrote:wouldn't the rear struts and brakes from a BZ-T bolt on same shape i don't see y they wouldn't
He dosnt have a BZ-T though, he has a Levin (donor)
As for replacing the whole subframe its not as hard as you think. Theres just two big bolts on either side holding it to the chassis. I would remove the exhaust before doing this. But Im not sure if its the same as a Levin one. They are the same on my Liftback and Wagon but they are both Corolla`s
And as for the CV`s, inner or outer??, which gearbox are you gonna use??, and if you are gonna use the Levin hubs just get Levin CV`s
20v_rollaboy
Postby bluemaumau » Tue Feb 14, 2006 5:36 pm
basically i wont be doing the engine for a few months but because my bearings and cv's are screwed i thort i might aswell do it now. so it would still be a 4afe gbox. hopefully i can get a ae101 4agze soon! :roll: :?
Postby bluemaumau » Thu Feb 16, 2006 5:32 pm
ok so ive bought them, now im thinking about it. anyone got any ideas on were i run the rear lines??? cuz ive got no idea.
also is it possible to use the gt-apex rear lines or will i need to buy new lines?????
thanks
