Surprised! No WAIC on drag cars.
Postby Stealer Of Souls » Mon Feb 13, 2006 11:29 am
Was watching the imports Vs V8 drags on tv yesterday and was slightly surprised that there was not a single WAIC...
Now I know WAIC isn't very popular, but given their reputation I would've though there would be at least a couple of drag cars using WAIC.
Is there some hidden insane probem with WAIC for the drag racing community in NZ?
'86 AE85.5 Levin
Stealer Of Souls
Postby CozmoNz » Mon Feb 13, 2006 11:37 am
Rayne For President!
CozmoNz
Postby Ako » Mon Feb 13, 2006 12:36 pm
Ours uses one :D
150 deg at compressor outlet, 30 degrees at intercooler outlet, thats with tap water. Ice water gets it better still.
Ako
Postby Adamal » Mon Feb 13, 2006 12:43 pm
Ako: Could your turbo BE any smaller??? :P
Postby Ako » Mon Feb 13, 2006 1:31 pm
IT CAN NEVER BE TOO BIIIGGGGG :lol:
26 kilos of Garrett GT47 Ball Bearing goodness 8)
Ako
Postby Mr Revhead » Mon Feb 13, 2006 2:28 pm
thats some impressive cooling there.... tried it with redline water wetter?
Postby Ako » Mon Feb 13, 2006 2:45 pm
It got tried, but figured it was easier (and much cheaper) to just jam heaps of ice into the water tank before each run :lol:
After doing the run, and coming back up the return road (which down here means do a lap of ruapuna :P) there's a little bit of ice floating about in the tank. No radiator on this one since it only needs to work well for about 2 minutes.
Its an awesome unit - however its MASSIVE and a lot of cars might not be able to fit it, and its not cheap either (though still cheaper than an HKS air:air or something).
Pressure drop isn't enough to do the car any harm - the gains are far outweighing any downsides.
Ako
Postby Mr Revhead » Mon Feb 13, 2006 3:36 pm
fair enough, drags are a bit different from my road set up i guess!
one day ill have ice box as well :D
Postby Stealer Of Souls » Mon Feb 13, 2006 4:04 pm
CozmoNz wrote:Docile not there then?
Oh. I thought docile looked like it had a AAIC.
Ako. Which car is that? I watched most of the show, but didn't really recognise most of the cars...
You should look at www.are.com.au and have a chat to them. They might be able to shrink that unit down a bit...
'86 AE85.5 Levin
Stealer Of Souls
Postby Malcolm » Mon Feb 13, 2006 4:10 pm
in many classes in the US w/a is outlawed due to the big advantages it has over a/a in drag racing. Obviously that's not the case here, so perhaps most of the NZ racers just don't like power? :D :lol:
Postby Ako » Mon Feb 13, 2006 4:12 pm
How could DOC1LE have an air to air cooler when the whole front end of the car is blanked off :lol:
Looks very Water - Air to me!
That car is my bosses weekend toy / our best advertising, ran 9.5 @ 141 so far, hoping for bigger and better things in the next 2 or 3 weeks.
Despite being used to great effect on drag cars, people still have the mistaken impression they are crap on road cars. They need a decent radiator to work to full potential, and being on TOP of an engine block won't help their cause. The cooler on the RX7 is a PWR cooler, same as the majority you see around the place.
Ako
Postby Malcolm » Mon Feb 13, 2006 4:17 pm
Ako wrote:Despite being used to great effect on drag cars, people still have the mistaken impression they are crap on road cars. They need a decent radiator to work to full potential, and being on TOP of an engine block won't help their cause.
I have a feeling that having an intercooler on top of the engine block could cause more problems than just inefficient cooling - like bad compression, big oil leaks etc :D :lol:
Postby Ako » Mon Feb 13, 2006 4:20 pm
Hrmm... Might have a point there.
So THATS where I've been going wrong all this time - keep mistaking head gaskets and intercoolers!
Ako
Postby snwtoy » Mon Feb 13, 2006 5:08 pm
Ako wrote:How could DOC1LE have an air to air cooler when the whole front end of the car is blanked off :lol:
I'm sure I read they're using something else in there.. dry ice maybe?? Could be wrong.
snwtoy
Postby mister two » Mon Feb 13, 2006 5:09 pm
Ako wrote:Hrmm... Might have a point there.
Ha ha... TOLD!
Current ride = suggestions welcome
Previous rides = 89 BFMR 4wd Sedan, 73 Fiat 124 Sport CC Coupe, 71 ke26 wagon, 1990 mr2, 1988 rolla hatch, and a cough cough.. sigma
I can't be without my car, even when i'm in the club I drive to the bar!
mister two
Re: Surprised! No WAIC on drag cars.
Postby Si » Mon Feb 13, 2006 8:08 pm
[quote="Stealer Of Souls"]Was watching the imports Vs V8 drags on tv yesterday and was slightly surprised ..............quote]
I was surprised at the lame ass coverage, hell, you could only see one car launch off the line.
then the whole pro tree issue.
then that $&#$% in the head commentator.
i turned it off after the 2nd round
Current: , '96 SubaruImpreza
Si
Postby Mr GTZ » Mon Feb 13, 2006 8:28 pm
I didnt realise on the day but yeah that damn pro tree setup was fcuked. It was more than obvious that was a big disadvantage to the Imports and one other thing if the Imports had won you know they wouldn't have shown it on t.v.
Mr GTZ
Postby Stealer Of Souls » Tue Feb 14, 2006 8:40 am
Looks very Water - Air to me! ... The cooler on the RX7 is a PWR cooler, same as the majority you see around the place.
Well. I'll be darned. They never show the car properly and i wasn't really watching all that closely apparently...
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr Revhead » Tue Feb 14, 2006 10:04 am
so how can the lights disadvantsge one side? sounds like excuses to me!!
Postby Ako » Tue Feb 14, 2006 11:02 am
It is an excuse, and a poor one. None of the drivers are using it either, just people arguing about it online who have never raced with both :lol:
Pro tree is no harder, you see the car before you use it, you just go "oh yup, that tree". Normally the clutch gets dropped on the last yellow, with a pro tree you just get one yellow. Easy peasy.
Ako
Users browsing this forum: Bing [Bot] and 21 guests
