Squeaky Clutch
Squeaky Clutch
Postby tomo1985 » Tue Feb 14, 2006 2:11 pm
I have a AE111. I'v just noticed a squeak when i push my clutch in. It's not coming from the pedal its coming from the engine bay. Is there any thing i can do to stop this???
tomo1985
Postby bad20v » Tue Feb 14, 2006 3:31 pm
Feed the clutch mouse some cheese? :?
You might want to grease up the linkages and check your gearbox oil etc.
8)
Thank-You.
bad20v
Postby tomo1985 » Tue Feb 14, 2006 3:45 pm
How do i check my gearbox oil?? Sorry im a noob
tomo1985
Postby sergei » Tue Feb 14, 2006 4:01 pm
for squeaky clutch you don't need to check gearbox fluid level, but clutch fluid level, which is located nex to brake fluid container on firewall in the engine bay. Clutch fluid is usually dot3/4 brake fluid.
Postby cespenar » Tue Feb 14, 2006 5:00 pm
I had a sqeuaky clutch, replaced the clutch fluid and that fixed it, made the clutch feel nicer too... this was because I don't think the fluid had ever been changed and over time it absorbs moisture, degrading performance and leading to potential rust issues...
cespenar
Postby CozmoNz » Tue Feb 14, 2006 6:47 pm
the sqeek is just the fork being moved in and out :-/
just spray some wd40 on it lol.
Rayne For President!
CozmoNz
Re: Squeaky Clutch
Postby Crucible » Tue Feb 14, 2006 7:31 pm
tomo1985 wrote:I have a AE111. I'v just noticed a squeak when i push my clutch in. It's not coming from the pedal its coming from the engine bay. Is there any thing i can do to stop this???
as in a continuous squeek that only disapears when the clutch is released? or squeeking only when the clutch is applied??
TNT
Crucible
Real Life Mechanic
Postby tomo1985 » Wed Feb 15, 2006 9:28 am
When clutch is pushed in only.
tomo1985
Postby RedMist » Wed Feb 15, 2006 10:51 am
thrust bearing
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby tomo1985 » Wed Feb 15, 2006 12:18 pm
It squeaks when you push the clutch in but only as pushing it in not while its in or out.
tomo1985
Postby peas » Thu Feb 16, 2006 5:57 am
Something to check though I'm not too sure if its applicable to this model. My GT-Four was making a similar sound and I tried everything only to find that the clutch pedal bracket mounted on the firewall in the cabin was tearing about the top mount for the pedal arm. Made a squeaking sort of noise and I eventually lost the ability to disengage the clutch. That is a barstard of a place to get to in that model as well!
'97 Caldina GT (ST215G)
peas
Postby Rob » Thu Feb 16, 2006 4:22 pm
If it sounds like its in the the car then lube up the pivot point for the pedal
1990 ST185H - project
1996 VS Acclaim wagon
Rob
