Info needed on removing engine from AE92 Levin...
Postby Stealer Of Souls » Mon Feb 13, 2006 8:37 am
Okay.
So. Followed the instructions in the book and managed to disconnect/remove everything I need to get the engine out except for the drive shafts...
I tried following the book, but can't make heads or tail of what I'm looking at.
AE92 Levin, manual. What's the best way of disconnecting the drive shafts from the gearbox? My haynes manual indicated that I would only need to take the gearbox end out... but I could be reading it wrong as it's not 100% clear to me... Should I just take the driveshafts out of the hubs first and then pull pull the shafts from the box? Or can I get the shafts out of the box without removing the whole thing?
Help me!
'86 AE85.5 Levin
Stealer Of Souls
Re: Info needed on removing engine from AE92 Levin...
Postby Punter » Mon Feb 13, 2006 10:10 am
Stealer Of Souls wrote:Should I just take the driveshafts out of the hubs first and then pull pull the shafts from the box?
Yes.
I've always found it easier to drop the whole subframe, but if it fits out the top good on ya
Punter
Postby neon_spork » Mon Feb 13, 2006 10:14 am
You can get the shafts out of the box while they are still in the hubs but its a bit of a pain. I would take them out of the hubs first and then pull them out.
neon_spork
Postby fangsport » Mon Feb 13, 2006 10:20 am
remove the axles from both the hub and box, hub end is usually done first.
the motor will fit out the top easy enough, depends if you are using a lifting winch or a lowering forklift. if the body is remaining in place while the engine is out, then probably easier to lower the motor onto a trolley/barrow, than to swing it clear of bodyshell if lifting.
fangsport
Postby Stealer Of Souls » Mon Feb 13, 2006 11:23 am
I thought as much...
Well then... Off home tonight to start removing driveshafts... Then the mission of lifting the engine... Starting to wish I could lift the car... but alas, given the situation... I can't....
Thanks again all.
'86 AE85.5 Levin
Stealer Of Souls
Postby ATAl » Mon Feb 13, 2006 5:59 pm
You can actually remove the engine without removing the gearbox, just remove all the accessories (waterpump etc) remove the crank pulley. Then support the engine, completly remove the cambelt side engine mount, unbolt the engine from gearbox and slide the engine out.
It's tight but does work, I've got an engine both out and in again by this method on my ae92.
ATAl
Postby Stealer Of Souls » Tue Feb 14, 2006 8:48 am
Was going to try this. But now I need to get to the gearbox mounts for someone so out comes the whole thing...
ATAl wrote:You can actually remove the engine without removing the gearbox, just remove all the accessories (waterpump etc) remove the crank pulley. Then support the engine, completly remove the cambelt side engine mount, unbolt the engine from gearbox and slide the engine out.
'86 AE85.5 Levin
Stealer Of Souls
Postby Caveman » Tue Feb 14, 2006 10:51 am
ive got a chain block you can borrow, will exchange for ae92 parts :lol: can also give you a hand if you want 8)
Caveman
Postby Stealer Of Souls » Tue Feb 14, 2006 12:19 pm
I've got a friends engine crane. So I'm good. But thanks anyways for the offer. :D :D
If you want parts, I've got lots and they're cheap. Make an offer on what you need...
'86 AE85.5 Levin
Stealer Of Souls
Postby deaf_rattle » Tue Feb 14, 2006 5:53 pm
got it out yet?
if not i can probably give you a hand this weekend
Postby gepsk8 » Tue Feb 14, 2006 9:22 pm
me and my mate got the front sub frame out after work one night when we wrecked an fxgt ae92, got all the loom out of the way, extra pipes and cables(eg. clutch,map senor, throttle body,fuel, radiator,etc) used the engine hoist got the front of the car about 1.4m off the ground at the front. put axle stands under the car bout where the doors are hinged. cut of the steerings arms got lazy. put the engine hoist on to the engine hooks just under tention. got under the car unbolt the whole sub frame then let it down slowly on the ground making sure everything was unattached to the motor & box. then we got a long chan around the front of the car and wheel it back bout metre and half out the the way of the sub frame. then picked up the whole sub frame put inside to strip it. took about 4hour i think
gepsk8
Postby Stealer Of Souls » Wed Feb 15, 2006 8:41 am
That's how the book says to do but I don't have some of the luxuries to make this option much easier than lifting the engine out.
deaf_rattle wrote:got it out yet?
I have't got it out yet. If I still haven't done it by friday I might take you up on your offer. I'm so close now though. As long as the weather holds I should be okay. I've just gotta remove the drive shafts, then unbolt the mounts and out she pops. So shouldn't take more than an hour or two (considering I've never removed driveshafts or anything like this before).
'86 AE85.5 Levin
Stealer Of Souls
