Engine Transplan - Final specs
Postby Infinite » Thu Feb 16, 2006 9:48 pm
Car : 1997 Toyota Curren
Current Engine : 3S-FE
New Engine : 3S-GTE
Converting gearbox to a ST202 (LSD)
Car is auto at the moment so i will be geting all the bits for that from a 1997 curren...
Using the E56s drive shafts to.
Going to get the Engine,Loom,ECU from a wrecked car that has a 3S-GTE
Then i will do the the piping for the engine with just brand new stuff till its runing...
Anything like new fuel pump ect ect i will need to upgrade?
Have i missed anything?, As i am starting to buy the parts next week. Thanks
Also were can i buy some of this stuff finding it hard to get gb/engine
Lots
Infinite
Postby THA SHZ » Thu Feb 16, 2006 9:56 pm
how bout u buy something that is already running like pies mr2 and then transplant everything over , as for the price u probably will be pushing it to get it off a wrecker 8)
THA SHZ
Postby Malcolm » Fri Feb 17, 2006 12:01 am
definitely should upgrade the fuel pump. Either use one from another 3sgte powered car, or buy a brand new walbro
Postby Jazza » Wed Mar 08, 2006 7:58 pm
Well me and infinate have the same ideas, what car would be best suited to rip the 3sgte out of? mr2, Caldina or a Celica? And would it be easier to mod the drive system to suit the engine, or to mod the engine to suit FWD?
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby Adamal » Wed Mar 08, 2006 8:12 pm
I wouldn't go for an MR2 engine. The alternator is at the bottom on the intake side. It would be a real bitch to get at in a FWD and would probably get in the way of something else.
Postby Caveman » Wed Mar 08, 2006 10:06 pm
Best car for engine MR2 turbo
Best car for gearbox - gtz levin/trueno
Its gonna get expensive
Go hard
Could be cheaper to rebuild your engine with stronger parts and go aftermarket ecu. This however requires more work and knowledge.
Caveman
Postby Jazza » Wed Mar 08, 2006 10:14 pm
Not worth it with my engine, it would be cheaper to do a 3sgte transplant and a 4wd conversion than trying to turb this heap of crap.
Jazza
Postby Malcolm » Wed Mar 08, 2006 11:01 pm
celica or caldina engine
mr2 turbo gearbox modified for use in FWD, as per the instructions on my website.
Postby Infinite » Thu Mar 09, 2006 9:19 am
*sticks to what all_fours has said all along >_<*
Lots
Infinite
Postby Malcolm » Thu Mar 09, 2006 12:02 pm
admittedly, if the ST202 Celicas have an E series gearbox then that will be easier to use than the MR2 one, but from what I understand you've had quite a bit of difficulty trying to track one down (or was that the other guy?)
Postby Jazza » Thu Mar 09, 2006 9:15 pm
The other guy, i just thought id hijack infinates thread to get a few questions answered myself :wink:
Jazza
