ROBODISCO_20v wrote:If you get the right duration and lift combo you can give it a broader power band. The previous owner of my Levin told me he had done the cams, when we had them out while doing a rebuild last month we couldn't find any marking/brand name or size on them, but what I can tell you is compaired to a standard black top & silver top it has way more pull from down low & it has even more after installing an Apexi SAFCII as it was running very lean at low revs. It still makes max power at 7600rpm so I didn't loose any top end & gained a lot down low. Just like a VTEC only better, as its not a Honda
blue-smoke wrote:also i was thinking for a new igition coil , leeds and plugs for a small bit of a bite....
blue-smoke wrote: i was thinking that ze pistons only have space for the 4 valves ..... would i be cancelling 1 valve out?
