cert question
cert question
Postby GTCRSHR » Mon Feb 20, 2006 11:22 am
Hi guys,
just a quick question
when getting air bags/adjustables cert'ed do they cert it at its lowest point or the point for daily driving ?
or
who would i need to contact (ltsa) wise for a definate answer ?
Nothing to see here ...
GTCRSHR
Postby Mr.Phreak » Mon Feb 20, 2006 11:28 am
Ring your local Certifier for a reasonably definitive answer
http://www.lvvta.org.nz/LVVCertifiersList-current.pdf
and http://www.lvvta.org.nz can come in handy
Mr.Phreak
Postby Jazza » Mon Feb 20, 2006 11:35 am
They cert it at a point and you are supposed to keep it on that setting. If you change it you are required to get it certed again at the new height - I think, dont qute me
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby wde_bdy » Mon Feb 20, 2006 12:11 pm
For airbags, the cert is for ride height. You can drop it when parked but when you start it up to move it must return to proper ride height. I believe this is done through a pressure switch setup, which most people then bypass once certed to allow them to adjust the ride on the move.
Adjustables is also for ride height, although they are pressing for a range of safe heights rather than the normal +/-5% for loaded and unloaded.
Callum
wde_bdy
Postby GTCRSHR » Mon Feb 20, 2006 12:17 pm
Thanks for that,
i have to have a word with them about the spacers/adapters
i shall double check with them on that also
thanks onece again
GTCRSHR
Postby johntramp » Mon Feb 20, 2006 2:15 pm
let us know what you find :) ta
johntramp
Postby Mr XXX » Thu Feb 23, 2006 2:30 pm
you need a switch on the hand brake so that they can only operated when the hand brake is on.... but yes, that is usually bypassed after.
Seedy Al's Chop Shop
Current Rides - 7-age At141 Corona, 81 kE70 Sedan, 1970 MS55 Crown, 72 B1600, ke25 Corolla x 2, Suzuki Carry Van x2, 910 BLuebird, 4age KP starlet
My Life Is a F*cken Project
Suck a Dx Chris
Mr XXX
Postby GTCRSHR » Thu Feb 23, 2006 2:31 pm
Mr XXX wrote:you need a switch on the hand brake so that they can only operated when the hand brake is on.... but yes, that is usually bypassed after.
yep got that,
no need to bypass after wards in my install
GTCRSHR
