20v RWD dizzy relocation
Postby Low_Aa63 » Wed Feb 22, 2006 4:55 pm
so hows the process coming with the relocation goodies?
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
hmm
Postby ezy10s » Sat Feb 25, 2006 11:58 am
yes am interested also, how is progress??
Oh also as for the issue of the distributor rotating the other way all you have to do is reverse your firing order to suit surely?
Member #244
Gone fishing until further notice
ezy10s
Re: hmm
Postby Ae92typeX » Sat Feb 25, 2006 12:36 pm
ezy10s wrote:...
Im tyred today so may not be thinking straight...but what about the advance?- that wont work in reverse
Ae92typeX
oh
Postby ezy10s » Sat Feb 25, 2006 12:47 pm
hmmmmmmm :?
Member #244
ezy10s
Re: hmm
Postby matt dunn » Sat Feb 25, 2006 1:07 pm
Ae92typeX wrote:
ezy10s wrote:...
No, and yes.
No because there is no mechanical advance in the dist so the teeth and sensors will still always line up,
and yes because the sensor is rotating the other way the a/c wave made will be backwards, so the trigger point that the ECU uses as it's firing point will vary with revs.
Kinda hard to explain, but if you played with magnetic sensors and link ECU's you may understand.
Matt
oh god
Postby ezy10s » Sat Feb 25, 2006 1:21 pm
waaay outta my league there matt
Member #244
ezy10s
Postby Ae92typeX » Sat Feb 25, 2006 3:50 pm
mmm, Ive been playing round with nissan dizzy's for the mini for too long, forgot the 4age one lacks mechanical advance.
With the reversed ac wave, the standard ecu would not function correctly wouldnt it?
Ae92typeX
Postby matt dunn » Sat Feb 25, 2006 9:17 pm
it should still work, but may advance or retard by a few degree's at higher rpm's.
Postby MetalupYoAss » Sun Feb 26, 2006 11:17 am
what does a backwards sine wave look like anyway?
MetalupYoAss
Postby matt dunn » Sun Feb 26, 2006 8:51 pm
MetalupYoAss wrote:what does a backwards sine wave look like anyway?
like a sine wave, but backwards, lol. :lol:
Basically,
if the first half is below 0 and the second half is above,
when backwards its first half above and second below.
Draw one and look at it in the mirror, :lol:
Postby MetalupYoAss » Mon Feb 27, 2006 9:26 pm
can you use a capacitor to shift phase angle 180 degrees?
MetalupYoAss
Postby matt dunn » Mon Feb 27, 2006 11:15 pm
MetalupYoAss wrote:can you use a capacitor to shift phase angle 180 degrees?
????????, dont know what you mean, but no, I doubt it.
It's not really worth worrying about.
Postby ENT1CE » Tue Feb 28, 2006 8:36 am
i run a mircotech on my honda they programed it to run honda sensors but mitsi ignition as i now run wasted spark with a mitsi crank angle sensor
it does make a difference if it spins backwards i have that problem with my honda and the mitsi dizzy i have to modifiy the guts of it
Current: 5 x ae85's 2 x ae86's, 12a b1600 ute, ek9 type r civic, tube frame drag body.
ENT1CE
Postby MetalupYoAss » Tue Feb 28, 2006 5:19 pm
when you put a capacitor in series in an AC circuit it can lead/lag the AC signal depending on the rating of the capacitor depends on the angle of phase shift.. imagine a sine wave leading by 90* it would the look like cosine wave so if you can get 180 deg phase shift the sine wave would be reversed to what it should be.. in theory
MetalupYoAss
Re: k tuning and fab on the dizzy is almost done
Postby matt dunn » Tue Mar 07, 2006 11:06 pm
kit wrote:ae86 20v turbo 16g setup home made manifold and honda ecu and wiring harness i'll be done in 3 weeks then i'll post some pic
3 weeks up?
Postby RedMist » Wed Mar 08, 2006 8:02 am
ENT1CE wrote:i run a mircotech on my honda they programed it to run honda sensors but mitsi ignition as i now run wasted spark with a mitsi crank angle sensor
Its not the running backwards thats causing you problems. Its the falling trigger. Honda's not only run backwards, they trigger backwards.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
