ezy10s wrote:...
Oh also as for the issue of the distributor rotating the other way all you have to do is reverse your firing order to suit surely?
Ae92typeX wrote:ezy10s wrote:...
Im tyred today so may not be thinking straight...but what about the advance?- that wont work in reverse
MetalupYoAss wrote:what does a backwards sine wave look like anyway?
MetalupYoAss wrote:can you use a capacitor to shift phase angle 180 degrees?
kit wrote:ae86 20v turbo 16g setup home made manifold and honda ecu and wiring harness i'll be done in 3 weeks then i'll post some pic
ENT1CE wrote:i run a mircotech on my honda they programed it to run honda sensors but mitsi ignition as i now run wasted spark with a mitsi crank angle sensor
it does make a difference if it spins backwards i have that problem with my honda and the mitsi dizzy i have to modifiy the guts of it
