another bloody 4age question
Postby samlloyd » Fri Feb 24, 2006 8:44 pm
Ive stripped all the interior behind the front seats 8)
And bought a couple of gauges just to chuck in to keep an eye on things
Water temp and Oil pressure.
I can see where the sender is for the water temp,
But can someone show me where the sender is for where i would connect the Oil temp to.
can you see it on this pic?
Thanks, (pics of interior soo)
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby Xyrath 86 » Fri Feb 24, 2006 9:00 pm
Its a little round thing next to the oil filter behind all the powersteering/air con shit on my engine.
Xyrath 86
Postby KinLoud » Fri Feb 24, 2006 11:14 pm
Oil pressure or oil temp?
Oil pressure - In your pic... just below the distributor will be a pressure switch or pressure sender screwed (depends a bit on what car it came out of) into the block, there will be a terminal on it to connect to the oil pressure light or oil pressure gauge.
Oil temperature - No 4age powered cars came out with oil temp gauge as factory.
Ken
Ham
021 408 863
Postby samlloyd » Fri Feb 24, 2006 11:48 pm
Thanks.
Its oil pressure kinloud.
I will go have a tutu tommorow. Hopefully i will be able to complete it, and rip more interior out!
samlloyd
Postby Caveman » Sat Feb 25, 2006 1:19 pm
Should be behind the ps pump under the distributor 8)
Caveman
Postby samlloyd » Sat Feb 25, 2006 6:49 pm
[rant]
oh fcuck stupid cheap crappy AutoGauge from repco. All fitiments plus a spare accesorys kit didnt fit the thread for the water temp!
Took that back and got refund
And the thread for the oil pressure is going to be way to big for all the fittings supplied with the oil pressure gauge!!!!!!!!!!!!!!!! GRRRRRRRRRR
taking that back for a refund tommorow
What gauges have you people installed on a bluetop 4age so i can buy something that i know will fit!!!
[/rant]
samlloyd
Postby Ae92typeX » Sat Feb 25, 2006 8:53 pm
not that it helps now you have taken back, but you can get adapters
Ae92typeX
Postby matt dunn » Sat Feb 25, 2006 9:07 pm
that's why the are called aftermarket,
because you have to modify them to fit.
Postby samlloyd » Sat Feb 25, 2006 9:16 pm
ah ok.
where do you buy adapters from?
Is it a bitch or what do get to that oil sender!
Stupid A/C Hoses in the way aswell!
Would electronic oil pressure and oil temp use the same sender?
samlloyd
Postby trueno_20v » Sat Feb 25, 2006 9:33 pm
smithers wrote:ah ok.
Na i dont think so..
ADMIN EDIT: signature too large
trueno_20v
Postby AE91Sprinter » Sat Feb 25, 2006 9:36 pm
no.
You'll want to get a T piece, engineering retailers will sell them, or perhaps repco or the likes.
Aftermarket parts cant fit EVERY car out there, else you'd have a billion fittings come with the part, doubling or tripling the price of it.
Ideally you'll want a triple fitting, to keep the original oil pressure light too - id definitely do it that way, you dont want to have to look at your guage all the time, because realistically by the time you did notice that you had zero pressure, it would be too late.
AE91Sprinter
Postby Dell'Orto » Sat Feb 25, 2006 9:38 pm
If you pay $30 for a gauge, cant expect it to be perfect eh ;)
Postby samlloyd » Sat Feb 25, 2006 10:52 pm
Can anyone point me to gauges that will fit stock into a bluetop? Prefered oil temp and pressure.
If i cant find any ill just do my brakes :lol:
samlloyd
Postby fangsport » Sat Feb 25, 2006 11:09 pm
most gauges are designed(read copied) off US manufacturers.there threads are usually BSP or NPT, whereas Jap car often have metric fine threads.
TWL and BNT stock adapter and T fittings for fluid and air lines. piece of cake to install.
fangsport
Postby Ae92typeX » Sun Feb 26, 2006 12:34 am
as above for where to go for adapters.
the standard senders quite probably wont work on aftermarket gauges- Ive tried that one before.
if you want standard fitting (water temp/oil pressure), just keep with the standard pressure and temp gauges as found on many 4age'd vehicles.
Ae92typeX
Postby samlloyd » Sun Feb 26, 2006 1:11 am
Point in way of standard pressure gauge :oops:
samlloyd
Postby NA Drifter » Sun Feb 26, 2006 2:52 am
I got some electric Trisco oil pressure gauge on my 4AGE. they fit fine. They are like $40 or something... brought it many years ago... hope this help.
Keith
NA Drifter
Postby Ae92typeX » Sun Feb 26, 2006 8:47 am
smithers wrote:Point in way of standard pressure gauge :oops:
aw11's, ae92's for two examples- both have standard gauges (but just bar indicators, not figures).
as NA Drifter says, there are ones which will fit fine- I was more pointing out that you want to fit the sender unit that came with the gauge, not use the factory sender unit for an aftermarket gauge.
Ae92typeX
Postby fangsport » Sun Feb 26, 2006 9:50 am
unless the sender and gauge a matched, they generally won't work as a set. take the factory sensors to BNT (from past experience TWL don't always stock metric) and get the appropriate adapter to suit . they are a couple of dollars each, which is a small price to pay for accurate readings.
fangsport
Postby samlloyd » Sun Feb 26, 2006 12:41 pm
NA drifter, was that a mechanical gauge where you had to run a copper tubing into the gauge?
Does anyone know the thread size of the water temp sender, and the oil temp sender?
Thanks all
samlloyd
