Pelo wrote:Ahh my car won't go! It is idling and missing at 600 rpm (just), breathing 5 in.Hg (vacuum) and has NO power! I have been hunting everywhere for a vacuum leak and can't find it anywhere. Any ideas?
4AZGE AW11 btw..
Mr Revhead wrote:havnt washed it recently have you? rained?
could be anythign from water in the plug holes to a broken wire on a sensor....
net mechanicing is so hard
Pelo wrote:So - who knows how to fix the key problem??
matt dunn wrote:cam timing jumped?
Pelo wrote:checked timing & timing belt & cam timing - ok
Pelo wrote:Ahh the crank pulley key has disintegrated!
the timing pulley was retarded at least 20 degrees or so.
True-No-Turbo wrote:No-Turbo"]
If the keyway in the crank is flogged out you may be in a bit of trouble, You maybe able to weld it as a temp repair like RS13 suggests but if it goes again you will need to replace the crank. That little key is under a lot of stress because of the supercharger and are pretty much under engineered from factory in my opinion.
tnt
keyway is only really there for alignment.
