I just got my injectors cleaned and was reading on a website that if you get them cleaned you should reset the ECU so that the engine starts from new.
Is this necessary and if it is how do I do it?
Its on a Trueno 5AFE if you need to know.
fivebob wrote:If you'd just bothered to enter the title of this thread into the search page you'd have all the answers you require![]()
However as you seem too lazy to do so try this viewtopic.php?t=35265
aesc wrote:Resetting the ECU on a Toyota doesnt do jack sh*t as they do not have a memory. And yes you could disconnect the battery...
OR instead of going to all that hassle you can just pull the ECU fuse out and put it back in
