Ignition type
Ignition type
Postby opticalblue » Thu Mar 02, 2006 10:39 pm
Hi does anybody know what type of ignition is on a 4age bluetop
Thanks
opticalblue
Postby l1ttle_d3vil » Fri Mar 03, 2006 8:55 am
how do you mean? what different types of ignitions are there? [stupid question no doubt!]
Postby opticalblue » Fri Mar 03, 2006 12:44 pm
need to know what type of distributor is on it a hall, optical or ....????
opticalblue
Postby slighty_sykotic » Fri Mar 03, 2006 1:02 pm
Vr pickups, and im struggling to remember if it's ESA or the other one...
--Sykotic
Last edited by slighty_sykotic on Fri Mar 03, 2006 1:04 pm, edited 1 time in total.
slighty_sykotic
Postby slighty_sykotic » Fri Mar 03, 2006 1:03 pm
VAST! vast is the other one.
Ill check what one the bluetop is
--Sykotic
EDIT:
Pretty sure its a vast, and the 20v and the 3sge are esa...
www.autoshop101.com/forms/h23.pdf
Read grasshopper :P
--Sykotic
slighty_sykotic
Postby matt dunn » Fri Mar 03, 2006 9:19 pm
opticalblue wrote:need to know what type of distributor is on it a hall, optical or ....????
slighty_sykotic wrote:Vr pickups, and im struggling to remember if it's ESA or the other one...
--Sykotic
What the?
Vr, ESA? ESA is electronic spark advance in the old commodore's but that's not the type of dist?
Bluetop's are magnetic trigger.
In fact 95% of toyota's are magnetic trigger.
Hall and optical need a power and earth to run them as well as the signal wires.
Matt
Re: Ignition type
Postby slighty_sykotic » Fri Mar 03, 2006 11:39 pm
opticalblue wrote:Hi does anybody know what type of ignition is on a 4age bluetop
Thanks
I read that, toyota calls it esa..........
I didnt read the one with the dizzy....
--Sykotic
slighty_sykotic
Postby vvega » Sat Mar 04, 2006 9:09 am
magnetic reluctor
24 x 4 teeth
in a bluetop
v
vvega
