My FX is squeaky
My FX is squeaky
Postby FXGTV » Sun Mar 05, 2006 3:24 pm
Started my my car this morning and heard a dreadful sqeaking sound comming from the engine bay :? Sounds like its comming from the cam belt or power-steering/alternator belt.
The noise continues when driving, but its less pronounced whilst accelerating.
Any ideas on what may be causing this? The cam belt was replaced 10,xxx ks ago, so i doubt its that, but i have had a problem with the power steering belt before (an old lead id left hanging dropped down and flicked the belt right off).
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby Jebus » Sun Mar 05, 2006 3:26 pm
Check the alt belt is tight.
Jebus
Postby TrouserFxGt » Sun Mar 05, 2006 7:38 pm
One of either water pump, alternator, idler, a/c compressor bearings?
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby FXGTV » Sun Mar 05, 2006 9:25 pm
I def think its the a/c belt. When i turn on the a/c the noise gets louder, so it stands to reason its that belt. Hopefully that doesnt mean its anything too serious....
FXGTV
Postby Caveman » Sun Mar 05, 2006 11:14 pm
I assume your talking about the car in your profile? ae92? always good to state what car your talking about :wink:
Anyway if its the AC then no worries, just the AC and PS suffer, nothing serious :lol: the tensioner is in between the AC and crank pully 8)
Caveman
Postby Leon » Mon Mar 06, 2006 9:44 am
open bonnet with engine running
carefully pour water on various belts (takes careful aiming)
when the noise changes markedly, that's the belt that is slipping.
Now you just have to find out if it is slipping because it is worn / loose or because your power steering or air con pump is trying to seize ;)
Postby FXGTV » Mon Mar 06, 2006 10:58 am
Haha sorry, yeah its my ae92. I poured water onthe belts and sure enough it got ummm ,squeakier when the water hit the p/s belt. I would tighten it myself, but alas, no tools. I've been getting some strange looks from pedestrians as i cruise the streets sqeaking like a mofo :lol:
FXGTV
Postby Jebus » Mon Mar 06, 2006 11:11 am
Its just your gilmer drives boss.
Jebus
Postby Chickenman » Mon Mar 06, 2006 11:34 am
If you can't tighten it ($&#$% simple job) you could rub a candle on the belt (just hold it against one part of the belt with the engine running) and it may help.
But you should just get a couple of spanners and fix it.
Baby Jesus
Chickenman
I Am The Walrus!
Postby FXGTV » Thu Mar 23, 2006 5:04 pm
Update: I've worked out it only starts squeaking when it rains/has been raining, and a short term solution to the problem was to use candle wax (thanks Chickenman) but this only stops the noise for a few minutes.
No biggie though, car is going in for an oil and grease next week so ill hopefully get it sorted out then :)
FXGTV
Postby 85AW20v » Thu Mar 23, 2006 10:23 pm
You mean it's going in for an oil - I doubt there's anything at all to grease!!
See ya
Simon
85 MR2 20v
85AW20v
Postby FXGTV » Fri Mar 24, 2006 3:35 pm
Simon85MR220v wrote:You mean it's going in for an oil - I doubt there's anything at all to grease!!
Meh, ive always referred to it as an oil and grease ;)
FXGTV
