intake pipes
intake pipes
Postby bluemaumau » Tue Mar 07, 2006 4:25 pm
ok ive been lookin at some 4agzes on the net.
im not being smart nor stupid,
but what is the advantage to using a stainless steel or "chrome" intake pipe? obviously it looks nice?
so wat are the pros and cons.?
cheers will :D
Postby Ae92 Levin » Tue Mar 07, 2006 4:38 pm
smooth polished surface flows air better, causes less turbulence in intake air and also resists heat better than the factory pipe, therefore keeping intake air cooler which means denser which means more power
Ae92 Levin
Red/blacktop bigport 4age (lotsa kays, still goes hard!)HKS Mushroom filter with Bunnings cold air induction ;) 4-1 extractors and two inch all the way thru, cat removed Oil catch can Aftermarket front strut brace
Monroe GT Gas shocks and struts with nolathane bushings
Anyone want to buy? just email me.
Ae92 Levin
Postby sergei » Tue Mar 07, 2006 4:43 pm
but most of bling pipes are not polished inside, save yourself money and use plain alloy pipe as the flow difference between two is minimal.
Postby Malcolm » Tue Mar 07, 2006 5:01 pm
even better, use PVC pipe because it wont conduct as much heat into your intake :)
Postby RomanV » Tue Mar 07, 2006 5:24 pm
And wrap it in tinfoil as a heat reflector, then zip tie it on. :lol:
Postby sergei » Tue Mar 07, 2006 5:28 pm
well PVC pipe is other exteme, it is too soft for some application and it can actually melt if it is near exhaust. I'm not fan of toilet induction, unless pipes are black.
Postby bluemaumau » Tue Mar 07, 2006 6:19 pm
ay good info. far i bet the alloy pipes that are polished inside cost a bit. lol.
Postby Malcolm » Tue Mar 07, 2006 8:32 pm
ha! laugh all you like but PVC really isn't that bad. You can put a layer of epoxy on it to prevent it softening (although I haven't seen it soften in an enginebay unless it's near something hot). It seems dodgy, but remember a lot of the factory intake piping is rubber or plastic, although I think the plastic used is usually ABS or something with a higher melting point, but it is harder to get in pipe form I think.
Postby bluemaumau » Tue Mar 07, 2006 10:11 pm
so what does everyone run on ther 4agzes? cold air boxes?
