shift light
shift light
Postby bundy » Wed Mar 08, 2006 6:32 pm
where can i get a tacho feed for my shift light on a 97 gt-t caldina
bundy
Postby deaf_rattle » Wed Mar 08, 2006 6:36 pm
diagnostics connector,
IG
put a terminal on the wire, poke it in there, and bobs your aunty
Postby trueno_20v » Wed Mar 08, 2006 6:37 pm
off the ( - ) wire/terminal off the coil?
ADMIN EDIT: signature too large
trueno_20v
Postby Lloyd » Wed Mar 08, 2006 10:02 pm
And does anyone have a wiring diagram of how to make a simple one from scratch?
Postby Caveman » Wed Mar 08, 2006 10:08 pm
trueno_20v wrote:off the ( - ) wire/terminal off the coil?
iirc caldina gtt has individual coils
Caveman
Postby craigt » Wed Mar 08, 2006 10:23 pm
Does the dash have a rev counter?? My shift light works perfectly off
this feed in my AE101 GTZ
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby bundy » Wed Mar 08, 2006 11:16 pm
i spoke to a auto sparky and he said you cnt get it frm the diagnostic plug and it has a tach in the factory dash. it has coil packs
bundy
Postby deaf_rattle » Thu Mar 09, 2006 6:33 am
bundy wrote:i spoke to a auto sparky and he said you cnt get it frm the diagnostic plug and it has a tach in the factory dash. it has coil packs
unless caldinas are different to most other toyotas that is bollucks.
have you had a look for yourself?
Postby bundy » Thu Mar 09, 2006 7:29 am
how do i fnd what wire it is at the plug
bundy
Postby Akane » Thu Mar 09, 2006 8:05 am
lol, fag.
Postby aesc » Thu Mar 09, 2006 8:47 am
In other words what deaf rattle is saying is that you just jam the wire to the shift light into the IG terminal plug inside the diagnostic box and have it running out of there its by far the easiest way. The terminal will be shown on the diagnostic box lid on the inside. I did that on my gtz for a while which also run coil packs and it worked fine.
Also depends what type of shift light you have, if it uses pills then you wont be able to take it off the back of the dash.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby BZR4AGE » Fri Mar 10, 2006 1:46 pm
just out of interest. my mate (who drives a ECHO - don't laugh, still a good runner) wants to put a tacho reve counter. I can't seem to find the diagnostic box anywhere. anywhere else I can connect the sensor feed???
BZR4AGE
Postby aesc » Fri Mar 10, 2006 2:11 pm
I think the diagnostic box is somewhere inside the cabin in those things, somewhere under the dash. Not sure exactly where though
EX AE101 owner
2013 Ford Focus ST
aesc
Users browsing this forum: Google [Bot] and 20 guests
