83 rona 3t to 3tgte plzzzz help
Postby L0w_st4rlet » Sun Mar 12, 2006 11:34 pm
hey just received a mint 83 rona prismatec orange low as but its only running a 3t haha i have searched it and have got the idea that a 3tgte will bolt in but that is all i can find and i have dial up so it SUX hard. will it bolt up to the t series box thats in there? only planning on running standard boost. and what about wiring will i need to completely rewire a new loom in there or is there a shorter way already being a 3t? already running an lsd. what would need to be done 4 cert has mean breaks. any 1 have a 3tgte 4 sale? any help appreciated am pretty new to this but have worked in a workshop so should be able to do it myself thanks any help appreciated. :D
L0w_st4rlet
Postby Ae92typeX » Mon Mar 13, 2006 8:23 am
It will bolt up to your existing box as its the same series engine. However, the box may or may not cope so well with it. Loom wise, it would be easiest to run a 3tgte loom & ecu if you can get hold of one...either that or aftermarket. They are around to buy- just depends how much you wish to spend. Finding a cheep one will take a little more searching, but:
http://www.trademe.co.nz/Trade-Me-Motor ... 164851.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 049988.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 163113.htm
For a cert, assuming all work is done well, you may get away with good quality pads on the front, but really, its the knid of thing you want to talk with your local certer with.
Ae92typeX
Postby L0w_st4rlet » Mon Mar 13, 2006 12:54 pm
wat would need to be wired this is wat ive been told correct me if its rong please i got told all i had to do was put engine and loom and comp in run a ground power wire and some other wire to comp and a wire to engine checklight? is this correct. if any one has done a similar conversion and could enlight me would be great thanx
L0w_st4rlet
Postby YeMs » Mon Mar 13, 2006 6:39 pm
nah man, abit more involved than that. personally i would throw the standard ecu and loom. get a link for $1000. wire it up yourself and get it tuned for like $500. and u will get abit more power etc from it, and will b able to run abit more boost (cos once the boost bug bites u will want bigger better and faster)
Your local Hybrid Elite tech
YeMs
Postby YeMs » Mon Mar 13, 2006 6:40 pm
also, u will need a bigger fuel pump, bigger fuel lines, some form of surge tank setup, bigger radiator, an intercooler (unless u wanna run it standard an un-intercooled)
YeMs
Postby L0w_st4rlet » Tue Mar 14, 2006 9:54 am
i dnt think i will need a link im only planing on running 10-12 psi i new i would need a bigger fuel pump would a holden exterior 1 do the trick and can i not get away with using standard fuel lines. never mind the surge tank just keep tank full
L0w_st4rlet
Postby L0w_st4rlet » Tue Mar 14, 2006 9:57 am
priced up some mods that thought was suitable 38mm external? 600*300 intercooler? ssq BOV? and just a under bonnet boost controller? are these suitable for this engine?
L0w_st4rlet
Postby 3T-Rona » Wed Mar 15, 2006 9:30 pm
L0w_st4rlet wrote:priced up some mods that thought was suitable 38mm external? 600*300 intercooler? ssq BOV? and just a under bonnet boost controller? are these suitable for this engine?
wont need the wastegate unless u wanna waste $500 for "the phatz sound bro"
3T-Rona
Postby L0w_st4rlet » Wed Mar 15, 2006 10:01 pm
yea bro got to have that sound aye that is off the sublect though im seeking advice on conversion
L0w_st4rlet
Postby SUBARUCONVERT » Wed Mar 15, 2006 11:03 pm
Dont waste cash on a external, just make a scremer pipe if u have to have the sound. 600x300 IC would be over kill for a stock engine
SUBARUCONVERT
Postby toyrota mota » Thu Mar 16, 2006 10:15 am
Whats a good(cheap) intercooler for these engines, then say if it was mildly upgraded, say exhaust, intake, turbo (proably a nissian one off a rb or v6), ajustable boost, bigger injecters etc?
toyrota mota
Postby L0w_st4rlet » Tue Mar 21, 2006 2:12 pm
looking for info on wiring now plz
L0w_st4rlet
Postby wde_bdy » Tue Mar 21, 2006 2:20 pm
Hit google, all the diagrams are on the net.
wde_bdy
Postby L0w_st4rlet » Wed Mar 22, 2006 11:19 pm
found a engine with computer and complete loom unplug not cut wat would be involved would most of it plug in or not
L0w_st4rlet
