4AGTE
Postby crnkin » Sun Mar 12, 2006 3:30 pm
hes sorta refering to what you want for big numbers, is a smallish exhaust housing, ie quick to spool on small capacity engine, a bigish shaft and wheel combo, ie flow big air, and a big comp cover, for big air flow. t3/ht18 is mint, has put out 350hp atw on a few cars on 8.0:1 at 24psi, go for it, do it
deaf_homo "currrently yes"
crnkin
Postby CAMB01 » Sun Mar 12, 2006 9:17 pm
Anybody got any of those parts?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Drifter4ag » Sun Mar 12, 2006 10:55 pm
ive got one HT18 for sale ... askling for $200 for it
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Crucible » Sun Mar 12, 2006 11:01 pm
CAMB01 wrote:Thanks :)
PM EvilSi, he had a HT18/T3 complete for sale :lol: .... I nealy bought it but another deal came up, He may still have it??
TNT
Crucible
Real Life Mechanic
Postby mister2 » Mon Mar 13, 2006 1:06 am
I think most of it has been covered... but a couple of rough formula's we use:
1L/min of fuel flow = capable of making 200HP.
So if you're shooting for 400HP you need around 2L/min at desired fuel pressure (static 43.5psi + say 25psi boost = 70psi).
Jumping to www.autoperformanceengineering.com they have flow figures for Walbro pumps and from memory the 255 High Pressure flows around 3L/min, way more than enough. You can test a pump in any car by grabbing a mityvac and pumping the FPR up to desired boost, and then energising the pump and measuring the flow out the return line for a given period. As a validation of the Walbro 255's, I have seen 533WHP made on a single pump, without dropping fuel pressure. Makes you wonder why people bother with anything else!
4AGZE pumps are ok up to around 12-15psi but then fall on their face.
2L/min of fuel /4 = 500cc's, so 550's should do it. Any bigger than this, idle control becomes an issue because of injector minimum opening times.
Don't use a bloody adjustable fuel pressure regulator.
Phil's AE85 (315WHP) was running a full To4e and around 22psi boost. I'd consider putting the 20v head on if I were you as it is a cheap flow upgrade, but it would require a custom inlet manifold. Go to single throttle, multi-throttle turbo's are difficult to tune and will require a very expensive ECU if you want it to drive nicely.
Megasquirts are great if you want to learn about ECU's work and are prepared to devote the time to it. Basically, find a dyno tuner you're happy with and they should be able to point you in the direction of a good ecu.
The world's greatest ECU will still destroy motors with a poor tune - and also, contrary to popular opinion, an expensive/higher spec ECU will by-and-large not make any more power than a cheap one, however it may drive nicer. Make sure it is installed properly - it will save you $$ down the line when the dyno tuner doesn't have to deal with your mates wiring!
Regards,
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Crucible » Mon Mar 13, 2006 1:04 pm
TNT
or heres another one - http://www.trademe.co.nz/Browse/Listing ... d=50335293
tnt
Crucible
Real Life Mechanic
Postby CAMB01 » Mon Mar 13, 2006 6:19 pm
Drifter4ag wrote:ive got one HT18 for sale ... askling for $200 for it
Is it just an HT18 off a nissan or something?
CAMB01
Postby crnkin » Mon Mar 13, 2006 10:23 pm
rx7 series 4, or series 5 has slightly better flow
crnkin
Postby ae92levin » Mon Mar 13, 2006 11:59 pm
mister2 wrote:Don't use a bloody adjustable fuel pressure regulator.
how come?
just asking..
Now: 94' Mark II grande; 92' gt starlet ha
then: x3 4agze ae92; 4agte ae92; e30 bmw
ae92levin
Postby evil_si » Tue Mar 14, 2006 7:38 am
Nick
thats a pretty bold statement.
care to share your opinions with us?
i personally have used adjustable/ and rising rate fuel regs on many cars, and they have worked really well.
i do however say to stay away from the cheapo generic ones on the market. they are more hassle than they are worth
evil_si
Postby mister2 » Tue Mar 14, 2006 11:46 am
Justification:
Firstly why do you need one?
1) if non-adjustable ECU (otherwise ECU can do it, right?)
2) if fuel pump is overwhelming factory FPR at IDLE
3) if you're *right* on the limit of your injectors
1) I will concede... however see caveats about quality below
2) is solved by choosing a fuel pump that is appropriate for your requirements, ie not a 600hp fuel pump on a bog stock 20v, or using multi-stage fuel pumps like factory (where they slow the pump down at idle)
3) is solved by not being so tight and instead of spending the cash on your bling FPR putting it towards appropriately sized injectors
Also, while I don't doubt that there are quality ones out there, all the cheap ones that I have seen have been crap quality - fuel pressure not returning to static after boost runs on dyno etc. And the point is, the only reason you bought a adjustable FPR is because they're cheaper than an ECU, right?
This is backed up by seeing the tiny factory Suzuki FPR on Monster Tajima's car at the Goldrush last year :lol:
So in this application (shooting for 400hp on a 4AGTE) I would highly recommend against using an adjustable FPR in favour of using an aftermarket ECU.
Regards,
Nick
www.nzefi.com
mister2
Postby :madaz: » Tue Mar 14, 2006 2:40 pm
crnkin wrote:hes sorta refering to what you want for big numbers, is a smallish exhaust housing, ie quick to spool on small capacity engine, a bigish shaft and wheel combo, ie flow big air, and a big comp cover, for big air flow. t3/ht18 is mint, has put out 350hp atw on a few cars on 8.0:1 at 24psi, go for it, do it
this is my view on a smallish turbine and big compressor wheel and shaft;
when a small exhaust wheel is mated to a big compressor wheel, you'll start having problems with exhaust manifold back-pressure, and therefore earlier onset of detonation, which will require you to take more ignition out of it and therefore power is lossed! further,If not ported, and running big boost with the smaller turbine, exhaust gasses are accelled at greater than the speed of sound, which will also cause backpressure issues.
porting will aid this and also a custom manifold which you'll no doubt have. otherwise id stay with a slightly larger turbine wheel, albeit it being 1.6 l.
speed on brother
hell aint ful yet
:madaz:
Postby CAMB01 » Wed Mar 15, 2006 8:29 pm
What are you talking about porting? Porting the turbine housing or porting the head?
The head is being ported.
CAMB01
Postby :madaz: » Thu Mar 16, 2006 8:49 am
porting the head! what sort of boost control will you use?
speed on brother
hell aint ful yet
:madaz:
Postby CAMB01 » Thu Mar 16, 2006 7:42 pm
Electroninc Boost controller
CAMB01
Postby CAMB01 » Thu Mar 16, 2006 9:41 pm
Have just done a piston height check in the bores, and they sit perfectly flush with the block surface.
CAMB01
Postby crnkin » Fri Mar 17, 2006 5:29 pm
I said small exhaust housing, and by bigish shaft/wheel combo, i meant bigish wheel combo, eg big both sides... your completely right in a way, except you didnt quite read what i wrote in the way i meant it to be understood :)
crnkin
Postby CAMB01 » Fri Mar 17, 2006 5:55 pm
I'm planning on getting a turbo custom made to suit my application
CAMB01
Postby Drifter4ag » Fri Mar 17, 2006 11:25 pm
hang on ... dont you want 250kw@fly ?
Ive already told you the recipe ..
all you need is my setup with a headport and some camshafts ..
or just a t4b front wheel on the ht18
dont try make it more complicated than it has to be
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby craigt » Sat Mar 18, 2006 12:07 am
Earlier in this post mister2 stated
"multi-throttle turbo's are difficult to tune and will require a very expensive ECU if you want it to drive nicely."
Can somebody please tell me why????
I would have thought if the ECU was getting an accurate stable vacuum/pressure signal then there wouldnt be a problem
With the MAP sensor working off a correctly dampened feed from multiple runners I cant see why it would be an issue
Lets see some opinions (and hopefully some facts) on that
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
